Thanks for your comment sir.Very beautifully built. Your gun ports are accurately designed. Thumbs up.
Thanks for your comment Jimsky.I like your small engineering in action! Well made!
Thanks for your kind words and your guidance. These links help me very much.Hi Bilal, congratulations for your job, the improvement in the carts of the cannons was really necessary and you have done it superb, as well as the chainplates.
In the thread of Scottola I've put a couple of links that can be useful for you both. And this one also...
INSIDE THE MONTAÑÉS
Greetings
Jaime
Thanks for your kind and encouraging words Donnie.Hi Bilal,
very beautiful Montanes - I love your longboat of the bright blue inside the hull. You are performing excellent work on this model.
You’re wellcome TechTrek. That’s what SOS for.Hi Bilal, thanks for showing your method for creating and installing the chain plates.
Hi Turkey. I am El CAPI. You contacted me but never came back. The decks with its accessory looks good, although I find the Deckhouse Windows and Doors out of scale. I know it comes with the KIT. You will have some problems later on with inserting the Guns on the main Deck and Riggen.Thank you sir. It's pleasure to be here.![]()
Dear Poul.Hi Turkey. I am El CAPI. You contacted me but never came back. The decks with its accessory looks good, although I find the Deckhouse Windows and Doors out of scale. I know it comes with the KIT. You will have some problems later on with inserting the Guns on the main Deck and Riggen.
happy building-stay safe.
Hi. It did it with a piece of planks -for second planking -and used the metal parts to mark, where it should be glued. used a cannonball as a doorknob. I have just this morning seen all the Pic. I Will copied them to my computer-with your permission- but it is petty that I have got them so late, as there- privately - are a few things to comment on. It is too late now to do it here.Dear Poul.
Thanks for your comment.
You're right. They are out of scale . I'm seriously thinking to change the metal frames with wood ones which I will make.
I havent glued the cabin yet. I'll install it after rigging because quarteck becomes too small to tie down the ropes with the cabin. Till then I'll have the opportunity to change
I installed all the guns but as we talked before 8 guns at below deck glued very hardy and without rigging. I wish I hadn't built the decks when starting the model.
I didn't want to bother you, as I know you're busy. I have your e-mail address and sure I'll have some questions to ask you when I'll start rigging.
Best Regards from Turkey.![]()
In shipbuilding I have two enemies: 1 To inserted and Glue the Decks from the beginning. You -if scared -can insert the main deck but fasten or glue it
2: The Dummy guns, especially the ones on the main Deck -covered with the Fore Castle and Quater deck
GENERALLY, YOUR SHIP NOW LOOKS GOOD
EL CAPI![]()
I bought a copy of the about 1978 when I moved to Spain. At that time there 3 Big Shops for model building- trains, plastic models of all king, ships kit, and any type of accessory for shipbuilding- the most part sold by bulk. At least one is still there ¡" Model Reyna" Madrid". There is another one Nother Spain. If they do not have the part you are looking for, then it mostly does not existMaking deadeye chainplates :
I dont like OCCRE's chainplate technique.
So I decided to make my own chain plates from 0.50 mm copper wire as follows :
View attachment 203386View attachment 203387View attachment 203388View attachment 203389View attachment 203390View attachment 203391View attachment 203392View attachment 203393View attachment 203394View attachment 203395
Yes they are done well, with holes ready for Gunport opening and closing.Thanks for your comment sir.![]()
