Hi All,
@Steef66 Thank you! I will do my best to post as many photos I can
hopefully they are clarifying as many detail as they should
@Alexander74 Большое спасибо за ваши добрые слова!
@Masters Mate Thank you very much for your nice comment
@dockattner Thank you. I'm glad you are enjoying my work.
@Uwek One more time... thank you very much Uwe for you kind comments. I'm happy when you guys finding it helpful!
@Gennaro Thank you for your generous and kind comment
but not sure if I'm such a Meister
but I'm glad you like it.
Parrel beads are made of brass. I found them in AliExpress... and few hundreds cost almost nothing with free shipping on top
Size... from 2mm to 8mm. 2mm it's actually bit less... some of them has ~1,8mm.
I must say blackening solution form JAX and Brass Black and other similar gave on the surface super solid finish. Really hard to rub it off.
@archjofo Thank you Johann! I'm always looking and dropping my jaw on your model. Your metal work and rigging is World Class. Le Creole is also on my list to build before I die
...and this time also I have some small update.
It was time to make fore and main course (sail) rigging.
So first I had to make blocks... one of the biggest on this ship.
...quick milling of sheave imitation on piece of wood.
Then just cutting individual blocks and shaping them by hand using files, sanding paper and sponges, et voilà, blocks ready.
Then I was ready to make fore and main sails tacks, sheets and clew lines.
Fore course
Main course
Also I've finished spritsail rigging.
You can see also big bulls-eye block attached to one of the fore shroud. Sheet pendant goes thru this block and then forms tackle fixed to the hull by ring and rope is belayed on staghorn seen in the background on the photo above.
You can see also first ratlines on the fore shrouds. This will be my next task... to complete them.
...and beside ratlines... only bowlines left... and rigging will be nearly done.
After that it will be this time where I have to "organize" whole rigging. Trim ropes excess , belayed them on corresponding pin, cleat, kevels and staghorns.
...and at the moment model looks as below
Cheers,
Matt
