Pocher 1:8 scale Lotus 72 [COMPLETED BUILD]
I just caught up Dean, you're simply the best at fine detail work. I think if you could pick the correct angle of just the motor and bare chassis, superimpose it on the right background, it just might be very hard to distinguish between the real thing.
FYI - For those of you who have been following, it has come to my attention through reports by many, that the build log updates are not being sent out to followers. So I advise you to manually check in on builds of your interest, as obviously we can’t count on being notified. Just a heads up!
I finished the upper radiator hose assembly…
As provided it was incorrect, there were two triangular pieces attached to it that are actually part of the motor. So I cut those off and will be attaching them separately after modifying them to look correct.
Here is the hose assembly after cutting them off and sanding…
Also next to the fill neck is a raised section that should actually be a hose with clamps. So I painted it black and added hose clamps I made. And for some reason they give you two black pieces to glue on that will connect to the motor, so those have to be painted. The other ends connect to the top of the radiators. So you have to glue and stab 4 connections at once after snaking them in between the struts. Fun!
I also painted the other hoses black.
On the car…
Now the triangular piece…
There are two, one per side. They should look like this…
As you can see in the upper left, it is part of the fuel injection slide, and should have springs and the end keeper plate.
I started modifying it and put one on the motor…
I am not completely happy with it and will do some more tweaking on it. Then I will make the other side. I also started adding the wiring to the ignition box…just getting started with those…
See you next time.
Thanks Paul! I plan to take them off and sand them with a fine sandpaper to get rid of the shine on the road surface. And then I will most likely paint the letters white. I just put them on for now to get it off the work table. ;)
Also next to the fill neck it a raised section that should actually be a hose with clamps. So I painted it black and added hose clamps I made. And for some reason they give you two black pieces to glue on that will connect to the motor. The other ends connect to the top of the radiators. So you have to glue and stab 4 connections at once after snaking them in between the struts. Fun!
On the car…
View attachment 379582View attachment 379583
See you next time.
Very impressive modification to the triangular piece Dean.
