Pocher 1:8 scale Lotus 72 [COMPLETED BUILD]
Just crawling in this corner of SOS finding a gem that's being build. Wow, just wow.....
Just wondering where you're going to place the stays and the ratlines.
I have staged all the parts up to page 21, they are all ready for assembly…
There are a few parts not pictured that have been painted as well, and are drying.
I also tested the fit of the rubber boot and axle shaft on the rear rotor hub…
Then I assembled the air box for the motor and test fit…
I continue to work on moving forward with whatever I can, whether it’s getting parts ready or making sub assemblies for steps coming up. ;)
Well…I had an episode of model madness! ROTF
I decided I had to paint the wire looms grey, because brass didn’t look right and black would make them disappear. But without getting paint on the plug wires or surrounding parts. And then I decided because I saw in a reference picture that the coil wire boot on the ignition box was red and the coil wire was yellow, that’s how mine should be. It would have been easier to paint prior to assembly, and the tiny rubber hose doesn’t want paint to stick to it willingly. In addition it would need clear coat and then have to be reassembled with tweezers without scraping or scratching the paint off. What could go wrong there?
That my friends is model madness! ;)
Also her: it’s in the details! A little madness is not bad at all, Dean.
Hi Dean,
Looks fantastic!
This is also my favourite F1 car of all time! I built the Tamiya 1/12 kit with Ronnie Peterson markings back 10 years ago. (posted a log on Blogger : http://f1lotusbuild.blogspot.com/)
Looking forward to seeing the finished model!
Cheers,
Peter
Thank you Peter! Welcome to pit row.
I will definitely look at your build. ;)
I think I am going to order the Tamiya 1/12 Lotus 78 too. I currently have the Tamiya Brabham BT44B in 1/12 and a Ferrari 126C2 in 1/20, in waiting. I may get my hands on the Renault turbo in 1/12 as well. Just love the classic F1 cars! I have a small collection of them (17) in 1/32 scale. So this is my first F1 model and I am already getting addicted! ROTF
Thanks!
That's a lot of cars in the pipeline.
I have only built the 72 Lotus so far as a favourite from my childhood back in Sweden, where teaching would stop and the TV would be rolled in for either of these three competing: Björn Borg, Ingemar Stenmark or Ronnie Peterson. :)
I also have the 1977 Lotus 78 from Tamiya in 1/20 scale.
Shipmodels and other things have gotten in the way though.
I'd love to try a Pocher model, but I don't have the budget for it unfortunately.
Peter
Thanks!
Peter
Well, I am in the middle of a ship build, and I have 2 more model airways WW1 wooden planes to build, 6 plastic airplanes, and a few plastic F1 cars! So once I retire I will have plenty to keep me busy! ROTF
I got the Pocher kit because it was on sell. I had been waiting for it to come out and forgot about it until I got an email from a vendor about a sale…and there it was! Fate was sealed at that moment, could not resist! ;)
Ps - I looked at your build on the Lotus 72, great job! Looks awesome!
Good morning Dean…now that is sexy.
….without a touch of insanity we would not be doing this hobby. Cheers Grant
Then it was time to join the two sub assemblies of the motor and rear end…
Not as easy as it looks…screw K has to go thru a hole in the back of the motor, with access thru a hole in the front!
Luckily I have an extension and a magnetic tip to hold the screw…still like surgery trying to get the screw in the rear hole without knocking it off the tip of the screwdriver…
And success at last!
Next step…already done while waiting on part! ;)
Next step…also done…
And the next step too! ;)
Which put me at this step…adding the hoses and the shifter linkage and housing that attaches to the rear…
Shifter linkage and housing attach here (lower left)...
And ends here at the front of motor, and will connect to the linkage in the body later…
And the hoses were added…I also added tie straps that I made from 1/32” wide strips (1/4” at scale)…
Was a bit tricky trying to bend and keep the braided hoses from flattening out, had to bend and then use needle nose pliers to round again. In the end I think they turned out ok.
