POF L'Amarante Corvette de 12 canons 1744 1:36 (Ancre Monograph- Gérard Delacroix) By Shota
good evening dear my friends
In the last week I continued to work on the initial adjustments that required to place the frames on the keel.
I reached frame number 20, an Amount that making it possible to get an impression along with the draft of the ship from the contours of the front third.
I also call in pencil the locations of the wills of the ship and the gunports.
As I mentioned the previous update ,I still have a lot more sanding work, adjustments and even repairs are required of me in some of the frames in order to reach an optimal result that will allow them to be glued permanently (after the installation of the nails that connected the two layers of each frame).
So until then you will be impressed by the small progress.
Good night everyone
View attachment 442105View attachment 442106View attachment 442107View attachment 442108View attachment 442109View attachment 442110View attachment 442111View attachment 442112View attachment 442113View attachment 442114View attachment 442115View attachment 442116View attachment 442117
Good morning Shota. Looking great. What wood did you use - looks like Pear? Hopefully not too hard wood as I see some sanding coming your way. Bravo my friend. Cheers Grant
Your shipwright is following your frolics rather closely; he's not a very trustful lad, I assume?
Other than that she's starting to show her lines; little by little, step by step working your way towards a masterpiece.
Hello Shota, you are on the right track, your hawse timbers have turned out very well. What I noticed is that it seems that you are too high with the hawse timbers and the first frame, but Christian and Daniel have already told you that. Secondly, your subframe that holds the keel is too high, you have to make it flatter otherwise you won't get a seat on the middle frames.
you are absolutely right my dear friend,I will fix it soon
thanks for your kind words my friend
my Dear friend Grant, you are right it's pear wood, and it needs more sanding work :) thanks for your support
Nice progress Shabtai. First time that I see those pictures on a large screen. Looks impressive, especially when considering your building speed. Waiting to see more;) .
Regards, Maks
my dear friend Maksym, thank you very much for your kind words and compliments. :)
I try not to rush and time is not plentiful either, I learned that the desire to progress and see results sometimes hides mistakes that require treatment.
Happy and peaceful Passover
Witaj
Bardzo ładnie to wygląda Shoto jeszcze dużo pracy przed tobą będę ja oglądał z przyjemnością. Pozdrawiam Mirek
Mirku, mój drogi przyjacielu Dziękuję bardzo za miłe słowa, komplementy i wsparcie na całej drodze
Mirek, my dear friend Thank you very much for the kind words, compliments and support all along the way
Hello dear friends
I would like to update with a little progress in the preparation and adjustment of the frames, I have reached number 28.
I share this time mainly that it is fun to see how the beautiful contours of the ship's hull are created and also because in frames 25-26 the installation directions are reversed and become opposites as I marked in the picture.
Good night to all of you> my dear friends, and to all those who celebrate Passover tomorrow, and to all human beings, I wish a happy holiday of freedom wherever they are.
20240421_221524.jpg20240421_221546.jpg20240421_221558.jpg20240421_222209.jpg20240421_222520.jpg
hello my dear friends
I would like to share with you that today the first stage of fitting the frames to the keel has completed.
I admit it is quite exciting to see the beautiful outline of the ship.
I would like to mention that this is a creation of 53 frames, each of which consists of 13 different parts to which the bow and stern parts are added. In total, there are about 700 parts that need to be manufactured as accurately as possible and adjusted between them so that they are compatible with the drawings from the monograph and in reality.
I estimate that for each frame I dedicated about an hour to sanding and adjustments until I was satisfied with the intermediate result.
I will share with you two insights from the process:
it is important to make sure to place the part on the growth lines/fibers of the wood so that they support the contours and structure of the rib.
In addition, the pear tree is convenient to work with, and even by wetting the frame in hot water, it can be expanded and even reduced a little (I mean the upper third of it).
Of course, I still have a lot of work waiting for me until permanent gluing (installation of nails in the frames as well as the filler parts in the upper third of the spaces between them). Until then, I wish us all peace and quiet and great enjoyment from our hobby:)
20240429_174405.jpg20240429_174452.jpg20240429_174654.jpg20240429_174736.jpg20240429_174841.jpg20240429_175606.jpg20240429_175718.jpg20240429_175840.jpg20240429_175902.jpg20240429_175925.jpg20240429_180014.jpg
I can imagine, that your small supervisor (standing inside the hull) is also happy with the result
Very good work my friend
thanks my dear friend :) for your kind words and compliments
yes the small supervisor, is satisfied :D
