Russian sailing-screw frigate "Oleg" 1860.Scale 1:100
A small update from the construction site.I built clews and eye bolts. I made the nail bars. Glued the exhaust pipe. So far, I've just attached it. He also made a movable platform with a cannon machine for a 60-pound cannon. I glued brass rails for her. So far, so good. I am waiting for the ordered adhesive copper tape.
Wonderful detail!
The bollards, bitengs, and nagel slats were used. I finished the light superstructures. I also made round light caps. The halves of the covers are cannon ports.
Great job you do.
Are there entering openings in front of the stairwells?
Were there any hooks for the canon's rigging on the inse of the breakhead? Or are they fixed on bronze slide rails, too?
Best wishes from Berlin, Christian
Great job you do.
Thank you for appreciating my work. Yes, rings with rings will be driven into the sides of the large gun port from the inside.The first question is not clear to me. What are the openings in front of the stairwells?
Highly interesting work - especially the brass gun rails - how did you make them? is it photo etched?
These are often very complicated form... f.e. the HMS Warrior bow 110pdr
I never found an information how these movements of such a gun were made
Thank you. These rails are made by laser cutting. About how the platform rode on them. In our group of modelers, they came to the conclusion that there were something like rollers from below. There was a hole in the front of the platform for a powerful pin. It was inserted through the platform into the holes in the rails, in the places of the U-turn. If you see spots on the rails, that's where they were. . The cannon itself stood on movable sleds that rode on metal rails of the platform itself. The rollers were mounted in the side walls of the machine, in the corners. I did not depict them on my scale. We just outlined the reinforcements in the corners. Well, they dragged the platform with the help of the same hoists with blocks.
I don't quite understand how these tracks work...
I'm no expert, but my guess is that the guns/cannons had a distinct pivot point with rollers following the tracks, hence the concentric circles of the tracks. Apparently there were multiple pivot points for different types of armament and may be also depending on the tactical situation. This could explain the intricate pattern of the tracks.
One might say that this is a step in the evolution towards the development of the turrets, as seen on later warships.
