- Nov 15, 2022
This is very nice work. Peter pointed out the delicate cut you made on your jibboom sheave. I second his praise. That cut leave very little room for error and one slip of a #11 blade and you could be starting over. Also, I just realized your approach to extending the lines on the mast top plans to ensure your alignment is correct on the support beams is a great method to use. And you end up with wonderful mast tops!!
I I have this kit, but put it on the shelf for a bit. It is not a kit for a beginner and while I do like Occre as a company and their customer service is extraordinary, the plans do require some additional research by the modeler.
I hope you don't take this too seriously and ultimately it is your decision, while I do like the color scheme very much and is the same I used, the color white is WHITE! It seems just a little bright. Perhaps once you've completed the model you might experiment, off ship, making a wash that you can brush over and mute the color a little. I rarely critique modelers as our builds are our builds and subject to our own desires. And if this is the case and you wanted to have the color white as bright as it is, just disregard my suggestion.
With that said, I love the work you're doing and wish you continued success my friend!!
Hi Hoss,
Thank you for your kind words.
For the mast tops i used @shelk method on his Santísima build.
And yes it's not a beginner build,and there's lots of research to do especially with the when the manual is not updated with the new parts in actual.
I don't mind the critique , on the contrary, i take it and usually I'm improving my skills and learning to achieve better results.
In this case the white is OcCre's paint and my client wanted varnish as well so it's looks very bright ,he doesn't mind the tone of the white so i'm going to leave it like this.
But thank you for your tip.
Cheers
Guy
