Re: OcCre Santisima Trinidad Build Log
<t>Donnie, Thanks for the reply, I think I can visualize it. <br/>
<br/>
Regarding most hobby mini-lathes that many hobby shops sell, you are correct they are all way to small for the likes of the kits that you and I are doing. I mean the two chucks you need to get, one rotating for the tailstock and one fixed for the headstock, can take up to five inches away from your working space, leaving only 11" of a 16" working space. That is why I started looking at actuall desktop mini-lathes, but you also need an extention bed for that. <br/>
<br/>
ShopFox is one brand that to me had the ideal solution, and it was like under $300.00, but let me find the invoice and let you know for sure what the entire lathe, extension bed, steady-rest and chucks all cost. Although the extension bed is a ful 18" long, making the "mini-lathe" about 45" long, and you wind up only using about five or six inches of the extension bed, but it is five or six inches that you REALLY need to have. Plus I additionall bought a steady-rest support just in case. It is a awkward looking contraption that consists of three or more wheels and a support arm that has a base attached to the track bed of the lathe. You place the middle of the rod through it and adjust the wheels so they firmly support the center of the rod, the wheels will turn with the lathe. <br/>
<br/>
Since I had NEVER worked a lathe before I also purchased an good instruction dvd and it helped a lot. You also have to get mini-lathe tools, not the HUGE tools used on full size lathe, and those can be found even on the full-size lathe sites. <br/>
<br/>
I have only tapered about three or four rods for the Royal William as a test and as nervous as I was I actually tapered one end of the rod down to an incredible 2mm and it did not break. I was quite pleased with it, I just have to set the lathe up on its own workbench to be more easier to use.</t>
