Silent Mary by Mellpapa
The next step is the handrail on the bow side. I said, I was making the handrail on either side of the lantern above the stern gallery.
The blue arrow decoration, in the concept illustration, is a lion statue...
Look out for the red arrows! In the film, it's a golden ball.
Let's make it a golden ball here, just like in the film.
Compared with images from the film.
Gold balls, should they have been a little higher?
Well, this is fine.
A quick glance at the picture shows that they are roughly similar.
It's a hybrid of a concept illustration and the CG from the film.
This is a comparison with the concept illustration.
It rather resembles the concept illustration.
I'm drawing a blueprint from a concept illustration.
It's no wonder they look so similar.ROTFROTFROTF
I am also having to play catch-up here. This is beautiful my friend on what has now become one of my all-time favorite build logs. What you have and are achieving by working from so little information and only pictures, is simply remarkable.
Hello, Mr Heinrich.
If you're a member of SOS, I think anyone can do it with their hands.
I think it might be easier than making a kit.
There are no assembly instructions, so you can make it as you like.
Instead, there are a lot of things that are wrong.
Prop in films like this one, detailed documentation appears on the internet much later. I'll be shocked then.:eek::eek::eek:ROTF
There is a skid in the area circled by the white arrow part thin red line.
There are steps under the main mast, two skids next to it and one skid on the bow side.
Make these skids.
Copy the curve of the hull from the frame drawing onto a 2mm thick plate, draw in the skid shape, cut out and cut away.
The skids are machined from 2 mm thick plates. You need three on the port side and three on the starboard side for a total of six.
It is not that difficult to shape them, so they are sandpapered to fit the hull and they are ready to go.
This is the starboard side.
There are some gaps, which will be filled later with epoxy putty.
This is the port side.
There are gaps here too, which will be filled later with epoxy putty.
◆Mysterious story of the film ◆
The image on the left is a CG composite of a scene from a film, but look closely. You can see that it is the port side.
The red arrow side is the stern. Look closely at the white arrow.
The steps and skids are on the opposite side of the ship, fore and aft to the bow side.
Below you can see an image of the Silent Mary's photographic set-up.
The red arrow is the aft side.
Look at the white arrow part. This is the starboard side of the set, and it is built like this.
The hull of a ship is normally built symmetrically. On the filming set, the port side may not have been built.
Maybe the film was shot on the starboard side of the set, which was then inverted and the stern section was CG-composited?
But the marine is pulling the trigger of his rifle with his right hand.
Did the CG operator simply make a mistake, or did the art director overlook the mistake...?
Is this a common mistake in films?
In Disney films, other ships, such as the Black Pearl and Silent Mary, are probably treated as props in the film.
So there may not be a detailed agreement on the details of each ship.
The sets have been built for the filming, so you'd expect them to match.
It's not a 'strange story', it's a 'sorry story'.
◆ port and starboard step craft ◆
Look out for the red frame!
Make the port and starboard steps. First or look closely at the shape of the steps. It's a stepped plank.
The top thin plank protrudes a little more than the bottom thicker plank.
I'll reproduce this.
There are two different widths of steps.
Look closely at the top picture.
They are 10 mm and 13 mm wide when sized for the model.
They are made by gluing thin and thick boards together, so you have to make two types of jigs before you can work on them.
The second photo shows the 10 mm wide jig.
The red arrow part is where the stepped steps are made.
Place a board 1 mm thick, 2.5 mm long and 9 mm wide and apply adhesive.
Note the red arrow!
Glue a 0.5 mm thick, 3 mm and 10 mm wide board to the glued area.
Completion of steps.
Enlarge image.
What do you think!!!
It's similar with steps, isn't it?
Twenty-two were made for both ports.
Next, 24 were made using a jig to make steps 13 mm wide.
This is a commemorative photograph of the 10 mm and 13 mm wide steps and their jigs together.
It was glued to the hull using 0.5mm brass wire and painted.
On the starboard side, with a different angle.
This is the port side, from a diagonal aft angle.
On the port side, this is an angle from the bow side at an angle.
The spacing between the steps on both sides is a bit disorganized, but it doesn't bother me too much, so I'll leave it as is.
I looked closely at both port and starboard sides and noticed.
The 'A' section on the port side is 4mm. The starboard side is 3mm.
Fix the 4mm gap on the port side to 3mm.
I fixed it.
You can tell even if it's 1mm different.
What? Not much difference?
Well...it's fine as long as I feel comfortable with it.
I am now 65 years old.
You have to revise the first sentence
You are now 66 years old.......
Hallo @mellpapa
Longer time ago, there was a song very actual in Germany
Mit 66 Jahren, da fängt das Leben an .....
At the age of 66, that's when life begins .....
Ihr werdet euch noch wundern, wenn ich erst Rentner bin
Sobald der Stress vorbei ist, dann lang ich nämlich hin, oh ho, oh ho, oh ho
Dann fön' ich äußerst lässig, das Haar, das mir noch blieb
Ich ziehe meinen Bauch ein und mach' auf 'heißer Typ', oh ho, oh ho, oh ho
Und sehen mich die Leute entrüstet an und streng
Dann sag' ich meine Lieben, ihr seht das viel zu eng
Mit sechsundsechzig Jahren, da fängt das Leben an
Mit sechsundsechzig Jahren, da hat man Spaß daran
Mit sechsundsechzig Jahren, da kommt man erst in Schuss
Mit sechsundsechzig ist noch lange nicht Schluss
Ich kauf' mir ein Motorrad und einen Lederdress
Und fege durch die Gegend mit hundertzehn PS, oh ho, oh ho, oh ho
Ich sing' im Stadtpark Lieder, dass jeder nur so staunt
Und spiel' dazu Gitarre mit einem irren Sound, oh ho, oh ho, oh ho
Und mit den anderen Kumpels vom Pensionärsverein
Da mach' ich eine Band auf und wir jazzen ungemein
Mit sechsundsechzig Jahren (mit sechsundsechzig), da fängt das Leben an
Mit sechsundsechzig Jahren, da hat man Spaß daran (mit sechsundsechzig)
Mit sechsundsechzig ist noch lang noch nicht Schluss
Lang noch nicht Schluss
Und abends mache ich mich mit Oma auf den Weg
Da gehen wir nämlich rocken, in eine Discothek, oh ho, oh ho, oh ho
Im Sommer bind' ich Blumen um meine Denkerstirn
Und tramp' nach San Francisco, mein Rheuma auskurieren, oh ho, oh ho, oh ho
Und voller Stolz verkündet mein Enkel Waldemar
Der ausgeflippte Alte, das ist mein Opapa
Mit sechsundsechzig Jahren da fängt das Leben an
Mit sechsundsechzig Jahren ist lange noch nicht Schluss
Quelle: LyricFind
Songwriter: Andreas Hofmann / Udo Jürgens / Wolfgang Hofer
Hello mellpapa. First of all i wish you a happy birthday.
As rather a newbie to this forum and as there is so much information to observe i have made it a small habit to check out the build logs of the anniversaries (sorry for those who i have missed).
I am truly impressed by your imaginaton and craftsmanship. The colors are spot on and give it the right somewhat sinister look. Your explications makes it a wonderful tutorial.
Herman
Hallo @mellpapa
[メディア=ユーチューブ]4ay8C8dAqEg[/MEDIA]
ラング・ノック・ニッチ・シュルス
Quelle: LyricFind
作詞作曲: アンドレアス・ホフマン / ウド・ユルゲンス / ヴォルフガング・ホーファー
Thank you very much, Uwek.
I completely forgot my birthday.
Thanks for the fun tunes.
I am 66 years old and live on my pension.
I am happy! Ticker, ticker, ticker.
Herman
Thank you very much, Mr Herman.
My painting will always include staining and ageing.
When I was younger, I used to build AFV plastic models a lot.
Whenever I painted, I always added stains.
Wooden sailing ship models are also stained and painted.
The Silent Mary is basically painted in German grey and drybrushed in light grey.
I do this because I think it gives it a more realistic feel.
I've never finished a model nicely.
I envy those who finish them beautifully.ROTFROTFThumbsup
Happy birthday my friend. I hope the the year ahead is a healthy one and that you will entertain us for a long time with such beautiful models like the Silent Mary!
Thank you, Heinrich.
66 years old. Am I happy or sad? I am.
Heinrich's Willem Barentsz Kolderstok 1:50, a very accurate construction, is wonderful.:DThumbsup
I'll add my birthday greetings to those already offered. This is also a great time to say how much I am enjoying your unique build!
Thank you, dockattner.
It'll take me about another year to complete it.
Vasa - 1:65 production, very nice.
I learn a lot from Vasa's original research, very informative.
I am also planning to build VASA Billing Boats, 1:75 one day.
I'll refer to you then, thanks!:DThumbsup
