Silent Mary by Mellpapa
Happy belated birthday greeting to you mellpapa. - 66? - lol I can't even remember that far back - Cheers and thank you so much for your wonderful presentation. Cheers :)
Thank you, ConsNZ.
I was 66 years old before I knew it.
Thank you, Bryantes.
I am now 66 years old. I am totally an old man.
How is your Silent Mary 1:98 production coming along?
No, only body is maybe little old, but your spirit still young, still many years of many experiences ahead of you :) Be strong, happy and full of life :)
And Mary, just few days ago i was finish first layer of planking and luting hull, and now i must sand hull but now i have night shift in work.
But few days ago i concacted hobbymill.eu about wood for second layer of hull, and some wood for deck. I will go with Dark Pear for hull and Black Hornbean for some strings. Next week will place order, meanwhile im working on beak, some Ai work and print, now i must just cut it and adapt it :)
After sanding i will post some photos of progres :)
And you are going well with Mary :) Im always happy if i see your new progres :) i can then thinking on my way about next steps with it :))
Have a nice day :))
Have a nice day :))
Hi Bryantes!
Your beard looks cool.
Silent Mary, you're making progress.
One of these days you'll overtake me!:eek::eek:ROTFROTFThumbs-Up
Make 10 handrail posts from 3 x 3 mm bars and 2 from 5 x 5 mm bars.
The handrail is built in using the posts that have been made.
Temporary assembly on the hull.
The thicker columns at both ends could have been made from 4 mm square rods.
But 5 mm square bars look stronger, so this is OK.
I am satisfied.
Make the handrail here.
We made a lot of props.
Now, the top of this part is the front side and the bottom is the back side.
Please take a good look at how it was glued in.
It's not cut and glued at 45°.
The posts are erected on the foundation parts with brass wire and the handrail is glued to them.
Well, this is how it is.
We will immediately try to temporarily assemble it to the hull.
This image is viewed from an angle.
This is an image from the bow side.
It looks quite deformed.
But it is emphasized and I think it is good.
It is my usual self-satisfaction.
Now the third handrail. It's the handrail on the top deck.
It was assembled according to the drawing.
This image is viewed from the bow side.
This image is viewed from the bow side at an angle.
ーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーー
◆Mini-drill story◆
The plastic case that used to hold the mini drill holder was broken.
So I decided to make one out of wood.
It is a convenient case that can hold a drill blade together.
When the lid is opened, this is what you see.
I set the drill blades I use most often in a pin vise holder.
Replacing them every time is a waste of time and a hassle.
From right to left, 0.3mm, 0.5mm, 0.8mm, and 1mm drill blades are set. The remaining three pin vice holders are free.
The white plastic case contains a dismembered drill blade.
The red plastic case contains a 20-piece mini-size drill set.
When I finish using it, I return it to this wooden case so it is never lost.
How do you all do it?;)
◆Mini-drill story◆
Love your organization! I may try building boxes for tools too but my problem is I have so many tools. I love building boxes!
I examined the rattles (rudder wheel) of the Silent Mary.
he rudder wheel appears to have 12 spokes.
The rudder wheel is doubled.
The spokes seem to be stuck directly into the drum section where the rope is wrapped around.
It's pretty hard to make this thing.
I drew a drawing of a rat (rudder wheel). It is still a very crude drawing.
I doubt if I can make it like this drawing, but I'll have to give it a try.
By the way, I checked out Capstan. It was just a glimpse at a ghost ship.
I'll just have to make it up as I go along.
I also drew a drawing of the capstan. The size and shape are not very precise.
As long as I am satisfied with it, I am OK with it.
Begin crafting the rat (rudder wheel).
Cut a piece of 0.2mm thick suture wood 1.5mm wide.
To match the inner diameter of the outer ring, we adjusted it by wrapping paper around it. The 1.5-mm wide pieces of thinly sliced suture wood are glued together with wood glue to make the outer ring of the rudder wheel.
The inner ring is also made.
Set the drum part of the rat (rudder wheel) and the double rings, and secure them with thinly shaved toothpicks.
It is a little troublesome because there are 12 spokes on the rat (rudder wheel).
I managed to make one of the rats (rudder wheel). As in the movie, the wheel is double.
Other parts were also made.
The wooden frame and grating that will serve as the foundation, and the front and rear pillars that support the rudder wheel. In the sailing ship in the movie "Pirate of the Caribbean," the rudder wheel is usually set on a wooden frame and grating as a foundation, and the rudder wheel is fixed to it. Ropes are threaded through the holes in the grating.
The other side of the rat (rudder wheel) is also assembled with 12 spokes.
After the spokes are assembled, they are cut, shaped, and temporarily assembled.
This is a temporary assembly of a rat (rudder wheel). I placed a 10 yen coin for size comparison.
It is the first time for me to make a double-wheeled rat (rudder wheel), so it is quite tough to make.
By the way, the Black Pearl and the Flying Dutchman's rats were made with 10 spokes.
Now, this is also painted in German gray.
After the German gray is painted, the fading is represented.
The same is taken again.
Temporary assembly on the hull. I placed it at the position of the rat (rudder wheel).
Rope is also set.
Compare with scenes from the movie: ......
I think it's pretty good.
It's self-satisfying.
