That's great!Yeah, it's made in the style of the 17th century!
Hello, Uwek.Very good solved - looking very good
Hello Rokket.Looks great. And big!
Hi Mellpapa, Congratulations you are making a work of art.FrankView attachment 427717
The remaining channel portion of the port side foremast, the red line portion of the chain, was made and set.
The channel portion of the port side mainmast and the red line portion of the chain were made and set.
This is the remaining channel portion of the starboard foremast, the red line portion of the chain is made and set.
Make and set the channel section of the starboard side main mast and the red line portion of the chain.
I don't like the chain that was installed last time.
This is not self-sufficient.
Fix the chain to the length of the white line at the point where the white line was placed.
The channel section of the foremast on the port side and the chain were repaired.
The channel section of the main mast on the port side was also re-chained.
The channel section of the foremast on the starboard side, the chain was repaired.
I also fixed the chain on the channel part of the main mast on the starboard side.
Now all that is left is the chain for the channel portion of the mizzen mast.
Hello, Frank48Hi Mellpapa, Congratulations you are making a work of art.Frank
Hi RokketShe sure is beautiful.
I can imagine brazing the brass would be tricky. I've always wanted to try silver soldering, but it see,s..scary and difficult!
