Soixantième Bluenose !
Bonjour,
J'ai collé 102 et 103, ce fut long et fastidieux pour tout aligner. Pour pouvoir travailler tranquillement j'ai choisi de les coller avec de l'araldite lente pour faciliter la tâche et avoir le temps de tout vérifier ! Je me suis inspirer de vos discussions pour fabriquer les petites pinces
Bien à vous, Dom
Bonjour,
Bien à vous, Dom
It’s looking nice, Dom. Good that you took your time, the alignment is important. And those clamps are very helpful.
Bonjour,
beaucoup de temps nécessaire pour coller 4 baguettes et les clouter, un peu brillant à mon goût...
Bien à Vous, Dom
Good morning,
a lot of time needed to glue 4 sticks and stud them, a little shiny for my taste...
Yours, Dom
Very good work, Dom. The inner strakes were laid very neatly and accurately. As to the simulated nailing, it all comes down to personal taste.
Hello Dom, I like the creative off ship prebuild at the openings. Looking forward to seeing how that works out. I like the 5th test piece from the left because it complements the grain the best.
Like you, I'm very interested in how those prefabricated parts work out.
Especially the one for the aft cabin.
@RevDom: I had quite some issues with the aft cabin, one of them being the spacing of the beams relative to the frames. Based on the cut outs you made in the part deck beams, you may have experienced similar issues.
Et oui mon constat est le même: j'ai du réaliser des encoches pour que les poutres soient au contact des couples et pouvoir garder le même espacement entre les poutres du pont. Vôtre journal montre bien ce problème, merci de l'avoir partager !
And yes, my observation is the same: I had to make notches so that the beams were in contact with the couples and could keep the same spacing between the beams of the bridge. Your diary clearly shows this problem, thank you for sharing it!
