So simple - so obvious - so ignored by me. Brilliant little spacer block to make sure the frames are perfect (there's that word again).
My model has a few of those gun port corrections. You have relax about changing the hull at this stage because no matter what you do, you can fix it and none of the fixes will be visible when it's done.So simple - so obvious - so ignored by me. Brilliant little spacer block to make sure the frames are perfect (there's that word again).
Hello Nigel, so far so good, very nice work ! One only detail you could correct is the shape of the gunports. They are not square, the bottom and upper sides follow the lines of the decks.
wow. they are amazing.Well I am please to say my large shipment of arms got through customs and I haven't been arrested
One complete set of cannons and carriages landed at my door to day this morning courtesy of Kris @SZKUTNIK.Both cannons and carriages are all sized to suit the different calibers.3D print work is top notch and requires the minimal of cleanup.A few of the Quion handles have broken off in transit but are still in the bags.A little job to glue these back on, can't be any worse than 1/700 photoetch
Half of the armament is still in the bags, only 36 and 24lb have been opened for the pics
Kind Regards
Nigel
View attachment 325725View attachment 325726
Hi Nigel.Well I am please to say my large shipment of arms got through customs and I haven't been arrested
Kind Regards
Nigel
Hi Nigel.
They look great, fine detailed work on the canons. Kudos to @Skutznik.
Looking forward to the finished canons on your model.
but I now have something definitive to work with for my heights between deck and lower cillGood God - it’s astonishing how detailed these really are! Fantastic stuff, Kris! If it can be done better than that, then I’d like to see it.
Ahoy NIGEL,.
We are very pleased, that you liked our products. If you still need our assistance, call us. We will try to help you.
Emergency Modeling Services - CALL 112![]()
Actually you can help, what is the best glue for sticking the little handles back on ? I am thinking CA or Tamiya extra thin?
