- Jan 21, 2022
Hello NigelI am having a break from Veneer for the time being as I have a potential issue that will get worse if I do not correct sooner rather than later.
There is a slight Asymetry in the topsides of the hull amidships.The hull will flex to the correct position but the more work I do on the rails etc, the stiffer it will become. I order to fix in the correct position I am going to instal the internal structure adjacent to the main mast.
As I touched on before, the mainmast needs to go in sooner rather than later as I have wiring that will be concealed for the lantern that sits at the rear of the top.
First job then is to build the main mast as I need to address the deck where it fits as there will be a boxwood insert that takes the mast and Elm pumps. My point of reference is the Saint Philippe Monograph rescaling to 1/65 from 1/36.Materials used are Boxwood and DIY store hardwood Dowel.
Order of construction is slightly different so I can cut a small slot with the Dremel to take the wires and this can be hidden with wood filler as this area will be fully painted. White for the mainmast, black for the top.
What is immediately apparent is this model will be huge when fully rigged and that the standard kit is way off from where the masting should be. When complete, the size will be near that of Caldercrafts Victory, remember though this is 1/65 vs 1/72.
Feeling quite proud, all the work shown below was completed in one day, yesterday. Lots more to do and I am tempted to build the complete mast and yards while I am focused and store everything for later, save the mainmast section.
Newbie question. If Saint Philippe is smaller vessel than Soleil Royal, don't you need masts from L'Ambitieux or the difference is too mall to consider?
Don't it need to be proporcionally bigger?
Heller's SR 1/100 gallery vs Saint Philippe's 1/72
