That is decidedly a good trait, IMO. So, is it a throat seizing and 2 lashings on the breaching ropes? Will you complete the blue veneer planking on the lower battery level before mounting the guns?
great work! Dear NigelWork continues slowly but surely, I have now started adding the dummy ends of the frame riders on the Starboard side after first drilling the holes for the breaching ropes and tackles. The eyebolts are from Dafi and I will be using his etched hooks on the tackle blocks.
The holes in the waterway below the ports are to take the brass dowels on the base of the carriages
Apologies for the pics, it is a gloomy day and pouring with rain outside
View attachment 403248View attachment 403249View attachment 403250
Here's a thought. If there are any drawings available, they could be digitally scanned in at a print shop such as Kinkos Print Service here in the USA, lengthened to 110% using a computer, and re-printed. It would cost you some money, but it would be well worth it as a aid in re-spacing the frames, gun port positions, and deck openings. While on the computer, you could also play with the image to see how a bias in stretching some portions of the ship more than others will affect the hull shape and other features. If you did not want to stretch the stern galleries, for example, you could stretch the center portion of the ship more than the after portion, so the proportions of the gallery fittings and carvings would not be affected, but the gun port spacing, deck openings, and mast positions would be.I do not at this point, I will look into it and I may lengthen the hull by 100 mm. It kind of sucks that it does not come with any scale drawings to layout and visualize
Excellent work Nigel.. I liked your work so much I went out and pulled the trigger and picked up the kit.
my wife wants to put it under the tree so I will start on it next week..
I am currently working on the Panart HMS Victory the Royal will be filler until the Victory is done.
I hope I'm not leaking any top secret knowlage. When I was discussing alternatives for Tanneron SR Kriss @SZKUTNIK said it's possible to make corret hull to Artesania's decorations PLUS fitt the decorations similar to what Michael Saunier's had on his model , also gun barrels same as Nigel @NMBROOK hasHere's a thought. If there are any drawings available, they could be digitally scanned in at a print shop such as Kinkos Print Service here in the USA, lengthened to 110% using a computer, and re-printed. It would cost you some money, but it would be well worth it as a aid in re-spacing the frames, gun port positions, and deck openings. While on the computer, you could also play with the image to see how a bias in stretching some portions of the ship more than others will affect the hull shape and other features. If you did not want to stretch the stern galleries, for example, you could stretch the center portion of the ship more than the after portion, so the proportions of the gallery fittings and carvings would not be affected, but the gun port spacing, deck openings, and mast positions would be.
It would take more work and expense, but the end result would be worth it.
Cost was below new "ultimate, super rare, collectors " VictoryIt would take more work and expense, but the end result would be worth it.
If I remeber corretly Nigel's modifications made it 1/65?? The stern bulkhead would have to remain the same size to fit orginal castings from Artesania. Rest similar to Nigel's work - lengthen the keel and establish correct gun ports.Considering Michel Saunier had the frieze ornaments printed for his model, it is certainly possible. The difficulty becomes deciding what scale and proportion for Kris to print to. And for that matter, there is a significant range for interpretation of what that frieze should be composed of.
Nigel's lines are definitely the idealized template. Truly, his efforts have inspired my own conception of what SR's architecture might have looked like upon launching in 1670, as those lines remained constant through the extensive re-fit. It would be cool, if Kris created a printed hull and ornamental set that matched what Nigel is doing. Of course, I am sure there are copywrite issues at play, there. Then again, Nigel has SUBSTANTIALLY transformed this kit so that it is almost completely un-recognizable from the source. Personally, apart from the cast ornamentation, I consider his a near full scratch-build.
