- Dec 1, 2016
Belfry work
Make the red arrow part, Belfry. Some books have the name Belfry.
Which is right...?
For the time being, I made a drawing.
I don't really know how the bell was installed, so I guess the bell is just right.
I'm not even sure about the bell-free feet. I also imagine this foot part.
When I made the 1/60 BP issue, I created it by my imagination without knowing that Belfry would look like this.
This time as well, there is some "imagination and creation", but I think it has improved a little.
I made a jig for the bell-free roof part.
Soak a 0.6mm-thick aviation veneer and 2 pieces of 1mm-thick cypress in water to absorb plenty of water.
This state. When the sandwich plate dries, it looks like this.
It's a close-up image.
It's dry, so I'll stick it with a tight bond and put it on the jig again.
It is a close-up image. Although the tight bond is protruding, it will be hardened as it is.
We will remove it later during shaping.
If you can't make a roof, you can't go next.
It is an idle play until it completely solidifies.
The material for the roof is complete. When making such parts, jigs come in handy.
The material of the roof part is divided into parts.
It's done by bonding the parts together... but it's a bit distorted. I'm a little worried...
After this, the parts of the foot were cut out, and the bell was cut out from the cypress and assembled.
Ummmmmm...
The roof and bell are rebuilt.
This is no good...
It is a remake of the bell.
I managed to get them...
Apply Tamiya putty to the wood grain, dry it, then apply plastic color gold and wait for it to dry.
I fixed the roof. I can't tell what's gone by looking at this alone...
Do people who understand understand?
Well, let's compare it with the last time.
Since A is the last time, B is the fixed roof.
The distortion was corrected. The horizontal edge of the roof has also been fixed.
It is painted and united with the bell.
done. I will shoot with a 10 yen coin for comparison.
Above the bar with the bell is the handle. Use this to rock the bell and ring the bell.
I don't know if this handle was on the movie.
When I saw a sailing ship's book, there was something like this, so I added it.
I installed Pinnacle, Rat and Belfry on the deck.
It's almost like this.
I took off the temporary mast and took a picture.
Is this the end of the outfitting parts work on the deck?
The rope handrail can be attached only after the mast is assembled. If you attach it first,
it will break when the mast is assembled.
The next part to make... ladder and channel... Is it a work on the side of the hull? Well, I made it
carefully without being rushed.
