Hang in there Buddy! It takes time and patience. These sailing ship models can sometimes take years. You're doing a great job!
Thank you for the support.Hang in there Buddy! It takes time and patience. These sailing ship models can sometimes take years. You're doing a great job!
Thanks. I gues I need to remember this kit was made in the 70’s.Well, there have been projects (models) I have worked on that I had problems w and did not necessarily turn out like I wanted. The main thing is to move on to the next step and I think you are trying to make the best of it of what I can tell. Besides, from the pictures, things look pretty good. So keep working on it. We are watching this one come to life.
Yes, I’ve seen that model but was a little timid as it’s been a while since I’ve done any model builds but I just might try that one. Thanks again.Well, maybe next time you can try out the wooden kit version by Modelexpo-online.com I understand that it is an excellent kit and has been built by many modelers. At some point, this will be my next build. This model is often on backorder and a good reason. They offer this model on sale several times throughout the year. If you buy it on sale, (and it is back ordered) you will at some point receive the kit. Hey, just a thought !!!
Instructions found here:
Parts list found here:
www.micromark.com
Minor point, but, you did ask for comments.......The bunks should be located in the bedrooms, not in the main cabin. The bedrooms (one on each side) are on each side of the main cabin. There are 2 locating stubs on the bottom of the bulkhead to get them in the right place. There is a bedroom for the Captain and the other would have been used by an Admiral or Commodore if on board. My instructions call for the inner bulkheads to be painted white. [I'm building the same model right now also.Well, the gundeck wasn’t too bad other than my eyesight for captains quarters. Started the cannons last night and those are a task in itself... again eyesight
This has probably been answered already, but the slots on the quarterdeck rail are for the "U"-shaped hammock netting supports. my instructions show 17 per side.Ok fellow modelers. I am at an impasse. Can someone please explain why the instructions call out 15 cleats for the quarterdeck rails and there are 17 slots for them? I have gone through the instructions to ensure that i will not need the extra 4 for future endeavors. Cannot see anything else, and as obvious as it may seem, I want to be sure.
Yeah, this is my first attempt in many years and I will definitely pay closer attention next time. That being said, I’m more disappointed with the sail booms as I’m at an impasse.Minor point, but, you did ask for comments.......The bunks should be located in the bedrooms, not in the main cabin. The bedrooms (one on each side) are on each side of the main cabin. There are 2 locating stubs on the bottom of the bulkhead to get them in the right place. There is a bedroom for the Captain and the other would have been used by an Admiral or Commodore if on board. My instructions call for the inner bulkheads to be painted white. [I'm building the same model right now also.
My kit is the 1976 issue.
I bought the wooden decks and cloth sails.
I think we may have different kits Coastie. I double checked last night and mine calls out 15 on each side. Then I looked at the instruction manual and noticed it was printed in 2014? I thought this was a 1976 version but guess I was wrong.This has probably been answered already, but the slots on the quarterdeck rail are for the "U"-shaped hammock netting supports. my instructions show 17 per side.
If they are the same scale, 1/96. they should be the same size. Did your instructions call for the interior upper bulwarks to be painted green, or was that your decision? Just curious.I think we may have different kits Coastie. I double checked last night and mine calls out 15 on each side. Then I looked at the instruction manual and noticed it was printed in 2014? I thought this was a 1976 version but guess I was wrong.
you could probably get some bamboo skewers that they sell in the supermarket (usually in the meat section) and make some passable substitutes. They should be about the right size, and, painted black should blend right in. They would be simple to make as they are smooth so the slide out on the yards. I'm not rigging stunsails, but the stun's yards are mounted on the yards, and the booms, which support the lower ends of the stunsails are stowed on the gun deck when not in use. I'll scan my yards and take measurements and send them to you if that would help. It's a pain trying to correct text!!!! Don't sweat the mistake. Everyone makes them. And, accidents happen. I just trashed a wooden model of the Model Shipways "Willie Bennett" because water soaked it when my icemaker crapped out and the water dripped into the basement where the model was sitting. I'm ex AF and CG and lived in Portsmouth and Va Beach for over 25 years.Yeah, this is my first attempt in many years and I will definitely pay closer attention next time. That being said, I’m more disappointed with the sail booms as I’m at an impasse.
Thanks for the idea. I was trying to think of a good substitute. I was stationed at Norfolk, VA for my final tour. Lived in VA Beach for about 2 yrs.you could probably get some bamboo skewers that they sell in the supermarket (usually in the meat section) and make some passable substitutes. They should be about the right size, and, painted black should blend right in. They would be simple to make as they are smooth so the slide out on the yards. I'm not rigging stunsails, but the stun's yards are mounted on the yards, and the booms, which support the lower ends of the stunsails are stowed on the gun deck when not in use. I'll scan my yards and take measurements and send them to you if that would help. It's a pain trying to correct text!!!! Don't sweat the mistake. Everyone makes them. And, accidents happen. I just trashed a wooden model of the Model Shipways "Willie Bennett" because water soaked it when my icemaker crapped out and the water dripped into the basement where the model was sitting. I'm ex AF and CG and lived in Portsmouth and Va Beach for over 25 years.
