Love the way you explain the level of details. This for sure will help others. Many thanks, Chris.
I will create a test circuit, thanks for letting me know.In order for the leds to flicker randomly, they must be wired in parallel, not series. In series, when one lamp flickers, it cuts off the power to the remainder so they all go on and off together. Ask me how I know.
Cheers and happy wiring.
Almost ready to glue down the main deck. Will do another dry fit and drill holes for wiring through the deck where the galley stove will be installed. I’m hoping the flickering LED will adequately simulate the fire in the stove.A very tidy bit of construction Chris!I started to put the transom pieces in place and the outside supports need to be angled with the side pieces that contain the cabin windows and gun ports. So I rethought the process and decided to glue the pieces directly onto the side pieces, when the sides get glued on the angle will be perfect. The small support pieces between the forward bulkheads were glued in place. Part 16 had to be cut down due to the bashed cabin, both pieces. I’ll need to figure out what I’m going to do with the internal structure behind the cabin side windows. I may need to cut some of it away after the sides are installed.
View attachment 207236View attachment 207244View attachment 207238View attachment 207240View attachment 207243View attachment 207239View attachment 207241View attachment 207242View attachment 207245
Thanks for the explanation.Looking good Chris. I can give you some explanation about the wiring of the led's. The main différance between parallel and series circuit. is as follows. In a parallel circuit The current is divided up and the voltage stays the same for all the led's In a series circuit the voltage is divided up and the current stays the same. So if you have 6 led's in series and a 6 volt supply you would only have 1 volt for each led.
Currents and Volts. . . I get confused enough trying to use the right glue for parts that I may have to later disassemble by some "solvent" to start over again and not mess it up again. The added feature of LED lighting and wiring is above my level. Nice opportunity though for your finished ship.Thanks for the explanation.
Good luck! I love your ambition! To be rendered in metal?Here are some various stove / fire-hearth plans I will be using to create my stove. Not sure which version would have gone on the HMS Fly as both have the correct footprint and chimney location and style. I’m leaning towards the 1st one as it is smaller and the Fly’s crew complement is 125, the 2nd style is for a larger crew (250).
View attachment 208762View attachment 208763View attachment 208764View attachment 208765View attachment 208766
I think brass sheet.Good luck! I love your ambition? To be rendered in metal?
