True storyBeautiful work Johan. Yes, overthinking is available in abundance on this forum. And just when we think we have it all just right we look again and exclaim: "what was I thinking?"
Good morning Johan. Fantastic! Really good work. Cheers GrantAfter dragging my feet for awhile, I could no longer postpone the installation of the bulwarks. The reason for delaying this step was that I had no idea how to position the partsforming the bulwarks onto the hull in a robust manner.
One has to consider that free passage of the later to be installed chainplates has to be maintained, the stanchions are nicely covered by the bulwarks and that the offset of the outer edge of the bulwarks, relative planking of the hull, is similar over the length of the hull.
After much reading and tinkering with the bulwark parts I came to the following process;
- Use a 0,5mm/0.020" thin strip to simulate the chainplates and insert that through one of the chainplates holes, see also @Peter Voogt's build, it's his idea, I think.
- Align the inner edge of the bulwark at the fwd and aft end of the parts with the inner edges of the stanchions.
- Drill holes 0,8mm/0,037" through and through and use some small nails of matching diameters, together with the chain plate simulation, to fix the position of the bulwark.
- Determine two other locations to drill fixation holes, depending on the deviations between the pre-cut bulwark parts and the hull (which is, of course, perfectly build...)
- After insertion another two nails, check the overall dry fit of the bulwark. Not that there's much you can do about it after drilling holes...
- Once satisfied, apply adhesive, reposition the bulwark and insert toothpicks through the earlier drilled holes and apply some pressure to ensure proper seating of the bulwark gains the upper edge of the first plank.
- Clean up any excessive adhesive and after allowing the adhesive to cure, cut off the toothpicks and there it is, a bulwark installed.
Below a picture of the first two bulwarks installed. The bulwark on the right hand/lower side is ready for touch-up, the left hand/upper side (as seen in the picture) bulwark is waiting for the adhesive to cure.
The red arrow indicates the fake chainplate, ensuring the bulwark doesn't move inwards, the blue toothpicks ensure robust retention of the position of the bulwark on the first plank. The green arrows indicate the bulwarks themselves.
The following picture shows, see green arrows, five of the bulwarks installed.
Still two to follow. Apparently I build my BN about 4mm/0,16" too short; I need to shorten the last two bulwarks by just that amount.
Thanks so much, Grant.Good morning Johan. Fantastic! Really good work. Cheers Grant
Hey Alf,Could you share any observations about how the Red Beech or Wild Pear (not sure which?) reactss from the soaking and bend forming? Is the grain-raising effect from the water hopefully less than objectionable or possibly even unnoticeable?
Nice to see how xy and xz comes together in this xyz-solution.Two of the vertical left- and right monkey rail parts were pre-formed in the xy-plane. Like I said, the process I use works pretty good.
Unfortunately, due to the sheer of the hull, I need a compound curvature on those two parts, otherwise I end up with pre-tension in those parts. Since I dislike pre-tension, I decided to try and add a compound curvature to these parts. Therefore I used the same setup,ensuring to maintain the desired xy-curvature and, to obtain the desired curvature in the xz-direction, I put some distance blocks (red arrows) at the extreme ends of the part and clamped the part down in the middle. And now we wait...
We'll have to wait and see how this plays out once we have the fourth dimension run its time.Nice to see how xy and xz comes together in this xyz-solution.
I'm so sorry, I am just assuming too much...Heinrich is lost - as he is every time that anything Mathematical is mentioned. I will, however, anxiously await the outcome!
What? Oh, sorry, I was looking at the flowers...I hope this makes a little more sense...
For a next explanation I'll make sure there are no distractions in view...What? Oh, sorry, I was looking at the flowers....
Starboard side:
In the front, it's the Buffalo Rail, Johan. It looks nice. And the rest is looking 'promising'.Especially for the so easily distracted @dockattner , I took some pictures outside with minimal background noise, I hope.
This afternoon I fitted the first preformed parts, in this case the breakwater (is this the correct term?) parts upfront. It was a walk in the park, the preform was close to spot on and I'm very pleased with the end result.
Port side:
View attachment 332990Starboard side:
I also performed a dry fit on the vertical rail parts of the monkeyrail. Looks promising, I will probably need a minimum of effort to have them bonded.
I also bonded in place the transom vertical parts of the monkeyrail, amongst others the selfmade cornerpieces. Also this caused me no issues during bonding.
A dry fit of the transom monkeyrail part confirms my earlier choices.
View on the inside of the monkeyrail transom:
Outside view of the monkeyrail transom
This picture shows a dry fit of the transom of the monkeyrail.
Ah, thanks Peter, didn't know that.In the front, it's the Buffalo Rail, Johan. It looks nice. And the rest is looking 'promising'.
Good morning. Monkeys, Buffalo - are you guys sure William James Roue was not visiting the Kuger Park when he designed this ship…In the front, it's the Buffalo Rail, Johan. It looks nice. And the rest is looking 'promising'.
Lovely Garden JohanEspecially for the so easily distracted @dockattner , I took some pictures outside with minimal background noise, I hope.
Port side:
A dry fit was performed on the vertical rail parts of the monkeyrail. Looks promising, I will probably need a minimum effort to have them bonded:
This picture shows a dry fit of the transom of the monkeyrail:
. Seriously tho she is beautiful. Cheers Grant
Thanks Grant, unfortunately autumn is coming, thus the decay of colors has made its entrance.Lovely Garden Johan. Seriously tho she is beautiful. Cheers Grant
Your build is coming along very well, and those top railings look first class. That is also something waiting for me ... again ...
