- Sep 3, 2021
Today was a fun day. While nearing completion of the hull, the focus is starting to shift to other sub-projects. The attention went first of all to the bowsprit. I delayed working on and installing the bowsprit, because these protruding parts are accident magnets and have a close relation with Mr Murphy.
Unfortunately the time is now to start working on the bowsprit, this has all to do with the foredeck becoming extremely crowded once all the bits and pieces are installed, leaving little to no room for later installation of the bowsprit.
With respect to the bowsprit, the YQ build instructions are sparse, but the drawings are luckily better.
Before pulling out the part, I checked, again, some of my predecessors' build logs, but also the website of the suburbanshipmodeler. After sketching what the part should look like, I decided to add the rectangular base of the bowsprit and also the diameter reductions at the tip, thus accommodating the hardware for the rigging.
Also in preparation is the Samson post, because as soon as I've inserted the bowsprit, it has to be attached to said post. Once the bowsprit and Samson post have been installed, I'll turn my attention towards completing the bowsprit; I want to add some bits and pieces not in the YQ build instructions, but that's for another day.
The base configuration: Since I don't have a large wastebin to select scrap material from, in other words no piece of 5x5 wood, I decided to use woodstrips of various widths to create a square base. I wanted a 5mm square base, so I sanded to bowsprit down to square 3mm, than added the strips of 5mm and 3mm wide. After curing I applied some chamfer and a transition from square to round.
At the opposite end I reduced the diameter of the bowsprit, more or less in line with what @Peter Voogt did on his bowsprit.
The unfinished bowsprit
Dry-fit with bowsprit and Samson post in place.
The Samson post still needs trimming, but the fit is great.
