In order to determine where I can or cannot reach with the 1st layer of paint or oil, I am further thinking about the deck beams.
In my post #372 I already explained that I am not going to let the top deck beams end between the frames, but rather shorten and 'lock' them between the 'Clamps', as shown in The Saga.
Nothing is shown for the beams in the lower floors. With the exception for partly the small beams between the 'Stringers', see my post #445.
To view what I mean: In the YQ manual, the beams are placed in front of the frames and extend between the frames:
I highlighted them in yellow. (Blue is coming soon
But this seems not logical to me, because how do they get the beams attached to the frames at the ends? There is almost no space for hammering between the frames.
But in this detailed account of the construction of the model by G. Bodnar using the drawings of P.F. Eisnor,
(see link:
http://www.modelshipbuilder.com/page.php?26)
you can see he placed the beams on the frames:
Here I have placed 2 beams in the hull to show the difference:
The front should of course still have the correct chamfer.
Thanks to the photo I can still see some pencil lines. Occasional shot of the frames while accentuating before sanding
If I move the beams to on the frames, that means that everything shifts 4.5 mm / 0,177” backwards. So also all blocks, with recesses, between the beams.
I made it blue in the photo of the YQ manual (see above).
Not a problem, because at the front of both blocks I can remove 4.5 mm.
At the raised lower deck at the front I have to see what can and cannot be done there. Because there are more blocks placed between the beams:
Of course I can just slide everything back 4.5 mm. The recesses are for the standing beams for the windlass and bowsprit.
I will still build the windlass scratch and the bowsprit can be adjusted. A matter of continuing to look ahead and keep planning.
Well, I still need some time to weigh up all the pros and cons.
Gr. Peter
