ZHL Black Pearl 2020 Golden Edition [COMPLETED BUILD]
On the All-Scenario Version, we got to make our own port hinges that actually work using two different pieces with ends curled and connected with a nail for a pin. It looks okay that way, but it's pretty rickety. I think you've done a great job with what they gave you. I've seen several that have a visible knot on the under side of the port cover.
Excellent work Tony. The jig and clothespin show your ingenuity and fine eye for detail. I’m very impressed and have archived your approach to review if it can be used at all for my ship! (Different version of the BP)
Thanks for the feedback I find with jigs simple is best, I was looking at ways to hold the lids in place while marking the holes. As the ports were different sizes making a block to fit didn't work then I saw the clothespeg on my bench job done. Just proves that a tidy bench isn't always a good idea.
very clever ideas with using these templates and jigs - very good work
It's time to do some of the parts I've been putting off for a while. I wasn't sure how to make them and they will stand out if not done properly, first one is the central staircase. Being curved and having to line up to the centre rail made it difficult, if they didn't turn out I was going to make them straight.
I have seen this method used but I couldn't make it work for me.
This is how I made the stairs luckily they are set at 45 degrees and I had a set square I could use if not a piece of wood (cut at 45 degrees and the same width as the stairs ) can be used. Firstly the ends of the stairs where cut at 45 degrees and placed either side of the set square held in place with magnets. As the sides of the stairs are different thicknesses one side was packed up to make them equal. The stairs are assembled bottom up.
As the stairs where fitted the set square was moved back using a rule to keep the pitch the same.
Last step fitted then the bannister uprights are glued in place.
The two cannons under the stairs went in first while I still had access then the stairs. The bottom centre bannister rail was lined up to the stairs and the uprights pinned and glued in place.
Side rails clamped to line up centre top rail.
Side rails attached.
Finished most probably could have been done easier but I'm happy with the way they turned out. Next the side rails on ship.
It definitely was not an easy process. The All Scenario Version. Had spindles as well as supports for the railings, making the build even more complicated. I was glad when it was done.
Wow Tony! Your work is really top quality. I can’t even fathom accomplishing that but I really appreciate the keen eye for detail! Your work inspires me to do so much more than I am capable of doing on my ship! Ahoy!
Very fine work really Tony, you are making it great. I'll Keep watching your job specially the finish of the lights
Very good result - and clever idea with the "jig" you were using
Thanks for all the likes and encouragement, I hope everyone had a happy Easter and not to much chocolate. I have been pushing on with the rails and head timbers.
The rails are difficult to get right mainly because of the round joining pieces lots of dry fitting and fiddling with the parts. All the blocks are pinned and glued in place. The parts where painted after gluing for a stronger joint.
When l started the head timbers I had no idea how to make them, they needed to be bent around the bow as they stuck out to much.l couldn't find a way of assembling them off the ship. I began by making some wooden parts to insure that both sides are equal. With the rails held in place with rubber bands the vertical rails where fitted one by one.
When all the vertical rails where fitted I removed the assembly and used it as a guide to assemble the other half.
As it's easier to fit now I made up the bowsprit, the end is angled to match the front bulkhead and a dowel fitted for extra reinforcement.
A piece of rope attached to the mizen mast was used to align the bowsprit.
With the bowsprit in place I fitted the middle rail with the verticals attached then trimed the height of the vertical rails to suit the top rail.
This is what I finished up with, its quite delicate and great care must taken when bending the rails.
Next up will be finishing the deck fittings then I'm saving the best for last the lanterns.
Any suggestions or questions please ask.
Stairway looks great, awesome, sweet.
Building the beakheads , you did a great job.
Cutting those groves in the beakhead rails without ruining the rails is quite an accomplishment.
I hope I can get my work to at least 90% of yours.
I've been thinking about how to make a stand for my BP didn't like the ZHL approach or a pedestal, so thought I'd have a go at making one. I am basing this on one I had seen on a website that would suit my BP.
This project started simply enough but then got a bit out of control.
This is all I really needed it held the ship well, the keel was locked in place and the bottom of the ship rested on rails keeping it nice and square.
A second rail was added for strength. To reinforce the glue I tried brass nails but didn't like the way they looked. Next best thing I made some 1.8mm wooden pins from toothpicks and pinned the joints.
A jig was made to drill the pinholes.
View attachment 220014View attachment 220015View attachment 220017View attachment 220018
Toothpicks reduced to 1.8mm blackened and glued in place.
Placed stand on keel and drilled 4 screw holes and one for a location pin, it's not going to move.
These are the contacts for the LEDs, the wires are not fitted yet.
This is how I planned it to be but felt that it didn't do justice to the ship.
Since I had wood left over some supports where added the problem was being on an angle glue wasn't able to hold them securely so these are also pinned in place. First I drilled holes (using the jig) where the supports are going, the support was positioned correctly and clamped in place.
The holes are transferred into the support.
Pins added ready to glue. After the supports where finished I added a brace to each one.
View attachment 220031View attachment 220032View attachment 220030
The pin is used to position the model so the contacts for the LEDs line up.
View attachment 220033View attachment 220034View attachment 220035
Like I said a simple job that wasn't so simple but I'm pleased with the way it turned out.
I built a similar base for my Enterprise 1799.
You however have taken it to a higher level. The detail and precision shows in the end product.
I would recommend putting some velcro pieces on the ends of the braces where they contact the ship.
This will save the hull from scrapes and scratches.
View attachment 225587View attachment 225588
Great job, Tony! Very clean. My beakhead posts did not fit and I had to jury rig them. Then when I turned the ship around to work on the other side, I broke them all off on one side. I hope they make the trip to Omaha without breaking again. I’m watching to see how others doing the All-Scenario Version fare.
I was afraid of braking things that's why I fitted the bowsprit early. This is one part of the kit that hasn't been designed very well.
Thanks I'll look into that, on my stand the braces are more for looks than function as the ship is held in place by the keel and they mainly only contact the wale.
I wish I could take credit for those groves but they're laser cut parts, this does however make them very easy to brake when bending. Nothing I have done is that hard just take it easy and find a way that works for you. If am having problems with a part it's time to take the dog for a walk when I get back the parts go together better, luckily I have a dog that needs a lot of exercise.
