ZHL Le Soleil Royal
Hello Jay
I'll be following your log
I have started my Soleil Royal about 1 month ago and do enjoy building her.
I have created a log for this (here)
Keep in mind that the instruction booklet from ZHL is fairly limited.
Looking forward to your progress
I have same kit, getting ready to start soon. Over the years (kits I've built) I've had to Spanish, Italian and now Chinese ;)
Hello Jay
Yes, I have been watching your build with interest. Very impressive.
Looking forward to you starting it. The more folks I can glean info from the better. More fun too.
According to the instructions I am supposed to attach the front and back part of the keel together and use part number 24 as a reinforcement where they join together. I decided to install the first four bulwarks first and make sure they were square. If you go by the instructions to me you might be asking for trouble as you could have part 24 too far to the left or right or lower then where the bottom of the bulwark is. 43A0441B-97B1-46D8-9257-EC86C88A1363.jpegC3FD89ED-A198-4699-98D4-AAF402133C0E.jpegEC7446D1-063C-487E-86BF-3DD53C0FF0BC.jpeg
Hi Jay
Looks good indeed
I have to say that I did not have any issue with fitting part 24 between the bulkheads
One thing I experienced though: the slide part of the bulkhead was quite narrow and hard to fit nicely into the keel. Not sure if you had the same issue.
Hi Jay
Looks good indeed
Actually I did find the bulkheads hard to fit on the longer keel number 15. On the putting together of the two keels I just wanted folks to be aware that tolerances may be tight and to dry fit and pencil place or install so they wouldn’t have problems later.
I dry fitted the bulkheads to make sure they were square and penciled in their positions then glued and made sure that they were square again using clamps to keep them in place.
If you look at my instruction sheet at the back of the keel there is a part number 6 that goes on top of the back part of the keel. I can’t tell you how many minutes I was looking for that part or why they had two parts with number 6 on the instructions. I got quite the laugh when I realized the part I was looking for was number 16 and the 1 was on the line. Maybe the numbers are a different color on the CD.
Looks like they wanted me to install bulkhead 12 and parts 22 and 23 on top of the bulkheads but I thought it would be easier to install the bottom decks before doing those.
If I can impart any thing just make sure you have something to either weigh down or clamp the decks so that they will lay flat.
I know there are several builds of the Soleil Royal so all of this might be redundant to you so bear with me. 71129124-1EFC-43E4-82FD-EC9617A87272.jpeg2C7AD47C-DE63-44E9-B712-8134754193E4.jpeg8808D24C-C097-4A5B-A2A6-1E595EB30CBC.jpeg
Always something new, Jay. This may be the only build a noob like me might see.
You might be right Vic, I just don’t want to be a yawner. On the bright side though doing the wood work is my favorite part of the build.
Got the lower decks on, wanted to make sure that they were all level. Don’t know if that will be a factor later on or not but guess it won’t hurt. Also drew the center lines on the upper decks while I was waiting for the glue to dry. 1610AE5F-82EC-46A0-80C5-E8C6E72A1707.jpegA31AB5E7-4296-4CAD-9B56-481CA5CA9572.jpeg
I dry fitted the main decks, every thing looks good but when I permanently install them they will definitely need to be weighed down. Viewing the instructions and I use that term loosely you might get the idea that you would install the rear bulkhead number 12 and the rear upper deck supports before you do the main decks. My advice is don’t do it. Just seems easier to do the main decks first and then do the rear bulkhead and supports.
Viewing the deck planking plan I think I will do some of the planking on the main deck before it is installed.
I also put together the rear bulkhead and will install it after I install the main decks. E5E8FAFA-3F42-4E8F-B9C0-A8B70421F03C.jpegA5DA9F48-0544-4A97-89DB-697D689F45D7.jpegEE8B226F-E467-4087-BC19-0AD809D3490A.jpeg
