ZHL Royal Caroline Kit, scale 1/30
there's a huge crowed of modelers chanting......
We want hinges, We want hinges, We want hinges........
Now you see this is exactly the problem, the Hinge Family don't live here anymore, they have moved to NSW, and now reside with a chap called Mr G Wood, some call him Peglegreg,
:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p:p
Well I like to keep everyone happy so here goes, I checked with the AOTship book and they only show the two windows on each end with hinges,
I hammered a pin into a piece of wood, and then bent some of the copper strip from the kit around it
Then nipped the strip tight on itself, took the pin out and CA glued the strip to itself, making sure not to get any
glue in the hole made by the pin.
Shows two on one pin and the start of another set on the pin below, the success of this is to get the strip nice
and tight around the pin, like the second pin
A set of hinges held up against the frame
so I glued the four middle skylights down as per the AOT ship book, and left the two outside ones on each side open
Another view.
Thank you Brian, for your comments, I'm sure you will not be disapointed with the RC kit,
well I thought before I do anything else topside I should finish the painting of the hull and all the carvings that go
under the transom.
these carvings come as one length and you have to cut them in middle so a carving can go on each side, also these
carvings are very thick and the surfaces they attach to are very rounded, see last two pics, I decided to do what
Maarten had done and cut the lower rail away from the figures, the carving on the left is still intact and the other
has been separated, these are just sitting on the planking not glued yet.
you can see how thick they are, and I have already taken some off from the top
section through the carving after trimming with a craft knife and sanding on a disc sander, they sit in place nicely now.
I glued the lower rails in place, and put the carvings away till after the painting is done,
I have started cutting out the hole for the rudder to go up through.
Just about the right size.
and after painting
bit more of a close up,
thanks again for visiting and watching my build, any questions just ask,
best regards John.
Very good progress. Your log brings a lot of fun and also hints for our models. Thanks for sharing with us on regular basis....
Well I gave the hull a good sandpapering and another coat of paint, then I turned my attention
to the area just behind the quarter gallery windows
this is the area that has to have carvings added to it.
this is a picture of what it has to look like, from the instruction book.
Adjusting one of the carvings for fit, there is a lot of cutting and adjusting
first up you have to make a framework, as in the next pic, these are the parts that you use, have to make one for
each side.
The framework glued in position, the figure is just being tried out for fit, and the lower figure is now glued in place.
another view
another page from the instruction book
The extra piece of decorative rail added on top of the framework.
another view different angle
showing how it will look when assembled.
transom view, the balcony frameworks will be waxed in situ, the other figures will be waxed off the model,
there are also a pair of dolphins that go above the figures.
G'day john
It looks like a lot of work for s SMALL area.
But there is one small thing that I noticed. Should the lady be more vertical than you have it. It mate an optical illusion.
Havagooday mate
Greg
G'day john
Havagooday mate
Greg
Its only being tested for fit , not yet glued,
best regards John.
These pics show me attaching the carvings
The figure now glued in place
and the twin dolphins attached above
close up of the dolphins, for added security I also drilled two .6mm holes through the
dolphins into the transom and secured then with the bras pins that were provided
I then ground down the pin heads with my dremel rotary
view with both sides attached
another angle
close up
Thank you Greg, Maarten and Uwe, and all who hit the like button, it is much appreciated,
best regards John.
These next pics show the fitting of the sheaves in the side of the hull
The brass sheaves and the laser cut frames
I drilled a series of 2mm holes big enough to take the sheave, and cleaned up the hole with a small file
The sheave sitting in place
and with the outer frame in place
I found that the sheave was as wide as the frame, and even with putting the sheave right to one side of the frame,
see sheave and frame on the right of pic, it would be hard to get a rope through, so as the sheaves were going to
be glued in place I decided to file a bit off one end of the pulley, see pic on the left, and then this would give more
room for the rope to go through
The back sheave is glued in place showing how it will be easier to get a rope through, while the front sheave is
just sitting in place to show what I mean about how hard it would be without filing the pulley down
The sheave for the fore sheet I believe.
In the end I decided to cut the aft part of the quarter deck out and place the new part in level with the rest of the deck
I cut it out square and also took the side and transom pieces out as well
then I glued in a piece of ply to the underneath of the forward section of the deck, and also a piece of wood to
either side of the bulwarks under the deck as support
shows the deck now sitting flush with the rest of the forward section
another view, once the side trims are in place you will not see any gaps
and the hull after the second coat of white.
