very fine work....
Soory Maarten for highjacking your log now:G'day Maarten
I'm sorry for the long time that i haven't looked at your brilliant log.
I've been quite sick and too tired to do anything. I'm just forcing myself to write this post.
In the time that ive away, your craftsmanship and your amazing techniques and imagination has, not only kept up to your un-human standards, but somehow, it has surpassed anything.
All I can say is that everything is Maartiffic! And you have again you have risen the benchmark to out-of-this-world.
I have been working on an English translation from the Chinese institutions.
I will post a pdf file for anyone who needs it. The grammar is not perfect, but it gets the message across quite good. I have made the pictures brighter and easier to see and they are more intertwined into the writen instructions.
Happymodeling my dear friend
Greg
Hi Greg,G'day Maarten
Greg
Just a brief update, I would like to ring the bell so time for a bell tower.
This is the kit supplied bell, the bell is ok but the clapper is a joke.
So time for an upgrade. from brass I made a new one on the lathe.
Then fitted it through the bell and hammered the end flat on the envil and drilled a hole for the final fitting to the bell yoke.
Last step is burnishing it to a nice brass appearance.
Next is a arm which will be fitted to the yoke to ring the bell. This I made from 1 mm brass fitted in the lathe and shaped with a file.
Now it still looks like rubbish, but hammer the end flat on the envill, drill a hole and bend it to shape and you get this.
In the mean time I shaped all the wooden parts for the bell tower, fitted together with brass pins for strenght.
My first idea was to fit the yoke between the bell tower with brass pins but changed that idea to spline connections which I made from 1 mm brass, 0,4 mm brass and brass plate.
In the legs of the bell tower there are two brass sheaves, also these I modified. For this I fitted a small round needle file in the lathe, moved the sheave with its hole over it and now you can rework the other shape of the sheave with a small needle file.
Time to fit everything together.
The name plate was supplied with the kit, it is etsched brass. I first gave it a clear paint coat, then painted it red and then removed the paint from the deeper etsched text to give it a golden text on a red background.
Finally dry fitting with a nice oil finish.
Many thx for your comments, just a fun kit to build, can certainly recommend it.Amazing. That model will turn out to be nothing less than a high quality, museum worthy masterpiece![]()
