- Dec 1, 2016
PART 8
Make S-shaped hook
Anneal a 0.5mm brass wire to make it easier to process.
I am processing the tip of pliers made by 100 yen shop. Jig for S-shaped hook production.
The tip is processed in this way.
It's just a shaving, but it's a special jig.
FD-043 of FLING DUTCH MAN production note
You appear in (laughs)!
Do the same thing to make an S-shaped hook!
Anodized 0.5mm brass wire...
Turn it around...
Change the pinch position...
If you turn it around...
It looks like this...
If you cut it with a snap, the S-shaped hook will be finished.
I was able to do this. But that's all for today. Ah! !
After making the S-shaped hook, I also made eyebolts and rings, and dyed the eyebolts black with gun black.
The ring is for train vehicles. I only need twelve, but there are more.
Make the ring an eyebolt for the traintail.
Wrap the wire harness (use the wire attached to the tag)...
Tighten the winding part...
Then, cut it to an appropriate length.
I made 14 pieces. Two are spares.
I dyed it in gun black.
I also dyed the S-shaped hook with gun black.
Next is the pulley...
It is a pulley for gantry. As with the production of the FD, the single pulley is machined
from a 1.5×1.5 mm square bar and the double pulley is machined from a 2×2 mm square bar.
I had a lot of work to do, so I couldn't quite make a model, but now I can do it. However,
this pulley isn't detailed... I'm tired.
I tried to make one gantry.
I need 23 more (sweat)
Maybe I should make a bleaching rope first (laughs)
It's boring to work with pulleys, so let's do something different.
Pay attention to the red circle in the photo. Apparently it's like a cannon storage area.
Looking at the drawing, you can see that three cannonballs are placed on each side of the cannon.
When I made the 1/60 BP, there was no such image, so I looked at the drawing and determined
that it was pin rail, but it was a mistake.
And the train train ring isn't on the deck. Since it's a shooting set,
did you remove it to prevent the actor from snagging and falling?
There is also a shooting set with a ring for train trains.
So I'll attach the ring for train train later.
I tried to make parts immediately.
Manufactured from 1mm thick and 3mm wide cypress, the length is about 8mm.
I stuck it on both sides.
Make S-shaped hook
Turn it around...
