The joinery is so good on the final piece that you should have embellished the perfect fit with fine black lines.After four misguided pieces i have made the first breasthook. There are a lots of things to learn on this part.
As a new model builder I don't have the milling tools and still rely on hand work and sharp blades. The precision in your notches made me wonder how you cut those so precisely. Was it all machine driven as you identify with the Proxxon MF tools? I don't know anything aboat that side of our hobbe and need to learn . . . or is it spend more of my ships stores sheckles for bigger boy toys? PT-2Thanks for you kind words, Uwe.
I used the MF 70 an the FF230 for this work. The FF for the scarf joint.
All notches are done but on the other side they are different !
I am off track here in looking as much at your build board/keel clamp and wood end bar clamps as I am at your excellent framing work. Please share some more views of just the bar clamps as I would like to copy and make some of those for my own use. . . or were they purchased? I have a hunch that you made those. Excellent work on both sides of my observations of which I am not experienced enough to make any meaningful framing comments beyond how well it appears to my novice eye. PT-2
I have to also agree with the recommendation to acquire and be able to use the right and good tools. Wrong or less expensive ones often lead to problems and frustration. I don' have a milling machine and what I have is not that accurate except by trial and error on test pieces to "find" the right adjustment; a combination of not enough knowledge and experience along with a tool that does not dial in precisely where I want it to do the work. My background has been and is more handcrafting but the more newly acquire "shop tools" are gradually becoming more comfortable to use but not as efficiently as a higher priced item, known by a member of SoS would be. Slow and careful to do the cut only once! As the hurried carpenter said, "I cut if off twice and it is still too short." Or the other side of the construction coin, "A good painter can make a finish carpenter out of anyone." PT-2Hi Oliver,
this looks very good.
Karl
deine Werkstatt , TOP !!!![]()
measure twice cut once. you can always cut another piece off but you cant cut a piece on.I have to also agree with the recommendation to acquire and be able to use the right and good tools. Wrong or less expensive ones often lead to problems and frustration. I don' have a milling machine and what I have is not that accurate except by trial and error on test pieces to "find" the right adjustment; a combination of not enough knowledge and experience along with a tool that does not dial in precisely where I want it to do the work. My background has been and is more handcrafting but the more newly acquire "shop tools" are gradually becoming more comfortable to use but not as efficiently as a higher priced item, known by a member of SoS would be. Slow and careful to do the cut only once! As the hurried carpenter said, "I cut if off twice and it is still too short." Or the other side of the construction coin, "A good painter can make a finish carpenter out of anyone." PT-2
That is a hoot!!!! Well quipped advice.measure twice cut once. you can always cut another piece off but you cant cut a piece on.
