link is no goodShota: Do you have a set of the Hahn plans? If not they are available through his son, Chris Hahn or through this link: https://www.navyboardmodels.com/store/plans/hannah
I think the link is correct, however it seems that the Navy Board Models website currently has some technical issues (since a couple of weeks ago)link is no good
dear DocI’m a little confused by your log! It appears you have several wood species for your frames. I can identify what looks like cherry, maple and perhaps poplar. What will you use for your final frames?
thanks again for your Advice and opinionLocation determines price. Where I live, cherry and maple, suitable for modeling, is actually fairly cheap. Cherry in “Select & Better” grade is costly, but you don’t need that clear lumber in long lengths to build models! Cherry in #1 Common will yield lots of clear timber in model making lengths (2-3 feet long).
Yup... very good tip. My Byrnes saw came with a blank plate. All I did was screw the plate down to the deck, turn the saw on, gradually raise the saw and let it cut right thru the plate - Done!!!make a zero clearance insert for the saw
