Take it easy and have a fast recovery! Get well soon!!
I want to say that I did not finish all the frames of this type and that I had more sanding and smoothing work left. Also drilling of the holes into which will be inserted the toothpicks that resembled the wooden nails that connected the boards in the ship parts.Can you slow down the feed speed to reduce the planer cutting head marks. Slower feed with the same cutting rotation will give you a more smooth surface reducing follow-up sanding. Same thing as rough cut lumber and S-4-S. Just wondering. PT-2Hello dear friends
Today I back to business, after the condition of the relative is slowly improving. I focused on adjusting the thickness of the Frame's boards using the Proxxon Thicknesser DH 40.
The work continued for about two hours at about 50 boards at a temperature of 40 degrees.
At first I moved each board individually,
but later I came up with an idea to streamline the process of running 2 lays together and it worked well.
Attaches the picture of the result.View attachment 177066
It's just fun to get back to work on the ship even if it's just in the preparatory work for building the Frame's
I wish to all of us lovely weekend![]()
I take your advice to my attention and apply it in the work process.Can you slow down the feed speed to reduce the planer cutting head marks. Slower feed with the same cutting rotation will give you a more smooth surface reducing follow-up sanding. Same thing as rough cut lumber and S-4-S. Just wondering. PT-2
