Hello my Dear Friends
It seems that whenever I plan to work on the Haarlem, something crops up!
 I had just started work on the interior bracing of the bulwarks, when the Bluenose just sailed right into my life! With that taking up the lion's share of my time during the last week, there was precious little time to work on my #1 build - but nevertheless, I have made some small progress. I actually feel guilty about how small - but here goes.
Even though it doesn't look like much, it is quite a time-consuming job. Each of those little spars has to be very carefully measured, cut to size (I use an X-Acto knife for that) and then glued into just the right spot at just the right angle. Of course the railing now needs to go on top of that, but I think I will first do the other side.
I also finished the 6 cannon carriages just so that I can get some idea of placement and of how it looks. Before the time, I was absolutely sure that they need to go onto the main deck area or in the "kuil" (in Dutch), but now I am not so sure anymore. I also placed them on the forecastle deck as per
@Pathfinder65 Jan's suggestion, and they look good there. So guys tell me what you think. The first picture is of the cannons on the main deck and the second one on the forecastle deck.
Hopefully I can start tomorrow on the bracing of the port side, but for now - that is all.
Your comments, thoughts and criticisms are - as always - hugely appreciated. Thank you all so much for looking and for following.
Kind regards -Heinrich
