Time for the first full frames.
I prepared 4 full frames 17-20, of which 17 18 is a double frame.
After fairing 17 18 I glue together with black glue.
And leave them to dry in place in the hull to ensure proper fitment.
After drying I remove the frame for again some fairing and sanding.
The double frame is bolted with 0,4 mm wire. Holes drilled to fit the wire.
Bolts are fitted.
And now time for @Jimsky 's magic the cup burr to finish the bolts.
Now the frame can be finally fitted and glued in place with white pva.
Followed by two single frames.
Bolts are fitted.
