Pilot House:
The last part in the height of the structure is the Pilot House.
On the drawing of the (Robt. E. Lee I) it is shown in this way:
With this inside design:
But in a previous post I had already shown this image of the "II":
The stairs do not pass in from an angle, but goes outside and passes at the rear with a stair to the roof of the Texas.
The web site www.Steamboats.com also has an archive with many photos, which also includes a series on Pilot Houses. There I found this beautiful image of a layout. And shows how big the steering wheels were.
SOURCE: https://steamboats.com/museum/davet-pilothouses2.html
So I had to make a new design. Just started drawing, cutting again the old-fashioned way and in the ground paint:
Roof, walls and floor.
Also for the roof immediately cut the roofing. Out of 1 piece, so only with 1 seam. Then the cut white ornaments will contrast nicely with that:
In order to continue with the design, I first had to have the most visible defining part, the steering wheel.
From left to right and from top to bottom:
-16 bars from Evergreen 0.75x0.75, 12mm long, with 16 fillings;
-glued together;
-painted;
-2 rings with the steel passer "cut" from copper foil;
-the 2 rings;
-merged and the handles given a red color.
But I wasn't happy about this.
2nd attempt, using my experience with mini-cutting:
-with a needle and the passer point a design made at 0.6mm Evergreen. Pre-drilling makes cutting easy. But on the outside ring the 1st handle already broke off;
-cut and sprayed around, that's already tighter;
-2 large and small rings cut and 16 handles from 0,8mm Evergreen, 2.5 mm long;
-gluing the handles;
-all put together and with red nails;
-all handles also turn red.
Sometime in the 90's I had already bought a steering wheel at about the right size. However, I knew in the back of my mind that that wheel was not going to be it.
Here are the 3 versions in a row. I already know which one it's going to be.
Now that I have the steering wheel, with how it gets into the wheelhouse, I can get on with the design.
-glued together;
-painted;
-the 2 rings;
