Great Project, and amazing finish! Make sure to invite for dinner, once the pig will roast! Booz on me...
Madness accrues! Just kidding - looking great, including that pig roast. Thanks.Now the tile floor joints are next.
I paint these with oil paint, white and Van Dijck brown.
As these joints are so small the paint which is outside the joints needs to be removed. My wife did this for me with a brush and some turpentine. She also gave some retouches to the tiles, resulting in my finished floor.
In the mean time I gave my pig some extra color.
When the paint and clay is hardened I will give some extra detail to the pig by scratching into the clay.
But for now this is it.
And to give you an idea about size.
This was a nice little project.
Hi Gents, thx again for all your comments and likes.When I see this huge number of frames -> looks like the framing of the CAF Le Coureur is an "Easy Going" or a "Walk in the Park"
Looking very good![]()
Outstanding job, Maarten! Gorgeous! You must be itching to cut her out of the building berth. After installing deck clamps? Thanks for sharing.Due to some extra hobby time these days my frames are finished, so now the major repetative work is done it will be more and more fun to build.
For sanding the inside of the hull I made foam pieces with sanding linnen glued to it with hotmelt glue, this helps you to properly sand all the inside curvatures without sanding dents into it. I made them with course 150, 220 and 320 to get a smooth surface.
After sanding the inside.
This is an interesting technique. Do you use a power rotary tool for this, or just a cup burr in a pin vise with hand turning?Then with a jewelers cup burr I transform the wire into a countersunk round bolthead.
I use Busch burrs for this on my proxon micro drill, works perfect.This is an interesting technique. Do you use a power rotary tool for this, or just a cup burr in a pin vise with hand turning?
Could you recommend a set of cup burrs? I see many online--diamond/carbide? Any brands that are known to be more durable?
Is this the burr cutter you are using?:I use Busch burrs for this on my proxon micro drill, works perfect.
Busch has the smallest 0,8 mm increasing by 0,1 mm up to 2,3 mm.
See page 22 in the attached brochure.
Yes this is the one I use for the 0,4 mm wire. For the 0,8 I used the 1,2 mm to get the countersunk effect.Is this the burr cutter you are using?:
I was able to find this retailer for Australian buyers:
BUSCH 411T TWIN CUT CUP BUR
All burs have a standard shank diameter of 2.32mm, which fit Jewellery Industry standard handpieces. These burs are supplied by Busch from Germany, who have been manufacturing their high quality burs since 1905 when Ernst and Otto Busch set up their dental bur factory Busch & Co. The...www.jewellerssupplies.com.au
