The Naval Cutter ALERT- 1777, POF by Jimsky
Putting a finishing touch and wrapping up assemble\installing frames...
One more thing I'd like to touch upon is double-frames. They do assemble the same ways as a single in the MDF jig. The difference, however, how you glue them on the rising wood as the final destination. So...what are those double-frames? Every second, or third frame - is a double-frame. It consists of two single frames joined together using bolts as the fastening. At first, I thought to imitate bolting on my Alert, I even made some test. But in the end, opted out an left as is 'bare naked' ;)
Here is the test frame.
Two single frames joined together will make a double-frame. But wait, DO NOT glue them all in advance! Here are the steps I outlined and follow while working on double-frames. Later, I will refer to double-frame as the set, with frame 'a' and frame 'b'
1. obviously, assemble both single frames
2. position (dry fit) frame 'a' on the corresponding recess on rising wood. Make sure the frame 'sits' in the slot. If you didn't widen too much the notches in the berth (top) for the end frames they should hold the frame in place.
3. dry-fit the frame 'b' (from this set) and make sure it 'sits' in the recess. Observe if there any gaps between the two frames. Get the flashlight inside the frame and look from the opposite side. Hopefully, you won't discover any...They should make one solid frame. If you see gaps, remove frames (both) and sand on the flat\even surface until the frame perfectly flat. Check against the glass.
4. Once both frames fit and there are no gaps, put the glue on the frame 'a'
WARNING:
a. DO NOT glue the recesses slots. Make sure there is no glue on either recess of the frame and\or the rising wood. We gluing the frame 'a' and 'b'
together.
b. Identify the area of the frame where the railing will be installed and mark it with a pencil. Do not glue this area. Later, when you will put railings,
it will save your time and nerves prepping frames for railing, Thanks Paul @paulv1958 for the tip.
5. while the glue is on frame 'a', insert frame 'b' make sure both frames are 'sited', aligned in their slots. Clamp frames for the glue to set. Depends on the glue you are using between 5 to 10 minutes.
6. carefully remove both frames out of a berth, get additional clamps, or let them completely dry on the glass under heavyweight. Congrats, you made your first double-frame! Thumbsup
You should have results similar to the images below
Once the double-frame is completely dry, it is ready for the next step. Frankly speaking, the next step is optional and you can finish by gluing the double frame to the keel. But in my build, I pre-shape the frame before the frame makes its final destination in the keel. The same way we use the templates for the cant frames.
Here is how the frame looks after shaping
This is how the Alert looking now...
closing the gap...2 more frames, babby!!!!
to be continued...
...and I can say: Mission accomplished! Final images depict the end of the framing saga.
While installing frames, I took advantage and glue the filling parts for the corresponding frames. This discussed on page 21 instruction manual. It is a straightforward process; those filling pieces labeled as the fraction digits, for example, AL38.5 This is the indication that this particular filling piece will be glued between frames 38 and 39 and so on...You may need to adjust the thickness of those parts so they will slide between the frames without excessive force.
Here are the framings completed! Because frames were shaped using templates, they required only a bit of sanding inside the hull to make a smooth transition for adjacent frames. Also, I use scrapers to emphasize bolting and make frames look clean. :) You may notice the difference between internal and external timber color. I used 'Artist's white spirit' inside the hull, just to see how the timber will look under oil. ;)
As a recap: It was a great journey into the world of framing, I have a very good impression of the framing process. It was as much educational as entertained! Repetition of making 80 frames will give you experience for the next framing process build. The assembly process was much simplified by using the MDF jigs, and templates to shape the frames make it a joy, The CNC parts make the assembly a breeze. You just have to pay attention! BTW, you should always do...
Framing Gold StarGold StarGold StarGold StarGold Star
Many thanks for your interest. We are closing this chapter and the next chapter will be Internal structure... Stay tuned and happy modeling!
Well...what can I say?! I am honored to be part of such a wonderful group of people! Your comments\feedback make me think I am doing something the right way which I am extremely happy about. I would be much happier if our group build logs will help other members in their kit endeavor. :) Please don't afraid to start your build log, we are here, and ready to help (if needed) ;)
Wait...It is still 11 days till the end of the year, you might see another post, or maybe two? Hmmm... did I said another post?
Many, many thanks to all of you. Thumbsup
Well...I was looking at this brick plinth and couldn't resist putting the iron firehearth and stove on it. Most of the day I spend assembling it. The parts are of very good quality and made the entire process a joy. Some of the parts like lifting eye and ring so tiny you must be very caution holding them. They tend to jump ;)
Here is the diagram from the AOTS book, I use it as the reference.
Below are the parts from the kit. They are cast white metal (but not pewter) flexible enough without breaking. Highest quality with lots of detail. I label them so easy to identify.
some macro details
The instruction manual explained the assembly sequence very well, as the assembly process is well defined and showed in 7 steps only using isometric images. Great job Triden Models @Trident Model.
Here, I started the assembly as instruction depict
View attachment 195689View attachment 195688
And the final product
As always, some details
I have to finish it by adding a few more details and will be blackened it before final installation on the deck. Now, it is time to build frames... Until then stay tuned for the updates. Many thanks for your interest!!!
Where did you get this kit? I can’t seem to find a kit for a 18th century galley stove
A question, the two or three darker center frame sections seen from inside and outside views, are they because of different wood to fix mistakes, or different wood in kit?
Thanks, Kurt, those are the Pearwood as the replacements for the damage and mistakes. Mostly my fault... I didn't have Cherry wood in my stash. The kit has a pretty consistent timber color per billet.
Hello Chris, The galley stove is part of the Alert kit. The kit has been purchased from Trident Model as an exclusive deal only for SOS members. You cannot purchase this kit elsewhere. SOS maintains the list of members who desired to purchase this kit.
Check this out, you may like it.
Thanks for the information. The CAF stove is the wrong scale I’m trying to find 1/64. I did find a stove that might work for my HMS Fly here
1/64 Stove
1/64 Stove
why not build from scratch? if you search the forum for a stove, you will find an entire thread discussing ships stoves with images.
