Rich, when you see the booms with the swinging stages and the main front mast, then its ready. But that is somewhere in 2021This is worthy of presentation in the SoS photo gallery. I hope that it arrives. Rich (PT-2)
Stephen, thanxs for the reply, the likes and the compliment.Magnificent work Peter,
All those fragile details, simply beautiful.
Cheers,
Stephen.
Well Peter, 2021 is just a few days away and the pier is open to your arrival, whistles blowing. RichRich, when you see the booms with the swinging stages and the main front mast, then its ready. But that is somewhere in 2021. Still a lot to do.
The pier may be opende, but without the swinging stages, no one can get on or off the shipWell Peter, 2021 is just a few days away and the pier is open to your arrival, whistles blowing. Rich
Thanxs Ted.Just superb!
Ted
Nice recovery on the railing and excellent job on the small boat! The Lee is a real beauty!Before I could attach the rowboat on the stern, I had to replace the railing on the back of the Hurricane Deck.
A few months ago, a metal square tilted against the railing. I was able to fix it, but it wasn't tight anymore.
A few weeks ago, when I returned the display case over the model, I hit the same railing.
It was more of less total-loss.
So, printed a new one from the restored files, hit the 1mm rounds and cut the rest. After spraying it was ready to install.
First cut of the old:
Placed some new uprights:
Forgotten to make a pictures when it was replaced. But ……
So I was working on the rowboats. First, the one at the stern.
What you see:
As shown on the drawings.
Is what you get:
The small hand winch for the pick-up and lowering of the rowing boat can (just) be seen.
And the ropes for the turning of the boom, neatly hung on the railing.
But also a view on the replaced railing:
With a little overview:
Excellent work Peter! She’s a real gem!It took some time and the necessary efforts, but also the 2 other rowing boats are fitted.
-4 oars with rowlocks;
-Rudder with 2 gudgeons on the transom;
-Eyes for the falls;
-A skeg to made the boat run straight.
Because the davits are simple booms that hinge right outward, I had to come up with something for the booms, when they are once upright, can't fall inside.
First dry-fitted.
On each little stand a holder with a fork and also a small winch, because the weight of a rowing boat you do not pull on 2 single discs pulleys.
The booms in place with already the ropes for the boat falls:
First the 2 booms, each with their guys attached to the floor/roof frame:
And with full rigging:
Because the 2 guys on the booms runs sideways outwards and backwards, there is a spreader between the 2 booms in the top, so they are not pulled outwards.
With more and more vertical lines, I have to pay more attention with the shooting. A little too close or a little too far wide angle and the outside sides bend very much outward.
The back is now also getting a bit fuller:
And just one more overview from behind:
Thanxs Dean. I had to look up the last line. It was not in my vocabulaireExcellent work Peter! She’s a real gem!![]()
Hello Stephen,To me it looks like you aregetting close to the end of this build.
Cheers,
Stephen.
I was forgotten to answer on this reply:Also the knowledge you have shared, the amount of bracing on these larger river boats is not something I had any idea of and the size of that helm / ships wheel is a lot bigger than I expected seeing the rudder looks quite small. I would imagine that any sharp turns would be done by stopping one paddle wheel whilst the other carried on, even better reverse one side while the other side is going forward.
Cheers,
Stephen.
Ha ha! Gem or jewel...learned a new word huh!Thanxs Dean. I had to look up the last line. It was not in my vocabulaire.
For a jem or jewel there are many carrots weight in this paddle wheeler!!!!Ha ha! Gem or jewel...learned a new word huh!![]()
