Heinrich, the beautifull lines of the Bluenose are showing now, what a marvelous work you and your Chinese friends are doing, my friend
I did forget the drilled holes. But it is not glued in yet, I will do it today.Hello Guys
FRAME 31
Since some of you may already have - or shortly will - assemble Frame 31, PLEASE NOTE THE FOLLOWING
Once Frame 31 has been completed and the glue has PROPERLY dried, you need to drill two 2mm (diameter) x 2mm (depth) holes in the frame notch as indicated below:
As promised, I have also addressed the issue of turning the jig upside down during the assembly process so that the frames can be slotted in from the top. Once again, I am relating the information to you as I have received it. It is by no means prescriptive and just indicates how the YuanQing test build was done. You are free to do whatever you find works best for you.
During the ASSEMBLY PROCESS, YuanQing keeps the keel flat as indicated on the pictures in yesterday's post. Only AFTER the rib and keel assembly is completed, is the jig turned upside down for the rest of the building process. It seems as if @Canoe21 Lawrence's closest to the process used by them - that of sliding the frames in from the side and positioning them in the keel and jig notches. Therefore, I would strongly suggest that all frames be dry-fitted into the keel notches BEFOREHAND, to make sure that you have a proper fit during final assembly.
PERFECT!!@Steviedean Hi Steviedean . Welcome to the Group Build and the Bluenose family! Your PayPal Bill is going out Wednesday morning the 6th of January, Sir! FedEx will start collections again on the 8th!
Is there will be provided a Skype or Zoom link for a video conference to join?Don starting tomorrow, I will build a beveled frame with you. I have done Frames 1 and 2 so we can do Frame #3.
Are we actually gluing the ribs to the jig?@dockattner @PT-2 Paul & Rich - It is quite funny that you refer to the Bluenose's keel as an edged instrument - you have inadvertently stumbled upon one of my other BIG interests. On its way to me (hopefully) is the Roxi 4 folder - designed by Seth & Terryl Todd from Montana and manufactured by WE KNIVES in Guangdong, China. (6AL4V Titanium Framelock / Ball-raced Flipper mechanism / 4"-long SV35N Wharncliffe blade.
And with that little side-distraction out of the way, I thought it best to pay some attention to the instruction manual and the procedure described therein that pertains to the mounting of the frames.
The translation of is of this page and refers to the section in the black-outlined "box".
The ribs and keel are assembled via the use of the building jig. First Frame #1 and #49 are glued to the keel. Place the glue in the notch of the frame and then glue it together with the corresponding keel notch (i.e.) Frame #1 will go into the first keel notch. Make sure that this fit is perfect. TAKE THE TIME TO CLEAN/SAND parts accordingly. The top parts of the rib frames are then glued and stuck into the corresponding notches of the building jig. Make sure that the rib frames are completely flush with the top side of the building jig. Follow the same procedure with the other ribs (Figures 29-32).
For the benefit of all, I have supplied you with colour pictures place of the Black-and-White ones of the instruction manual.
So you can see there is no mention being made of any upside-down construction techniques (at least not during this phase of the assembly process. However, I will ask YuanQing on Monday about those posted pictures and get them to comment.
Happy Bluenose building guys!
Hello Guys
FRAME 31
Why are these holes being formed?Hello Guys
FRAME 31
Good question to anticipate what is following a present unknown. RichWhy are these holes being formed?
Proudtower
