Does something like this (see below) is also happening to you sometimes?
Yesterday evening I was working / fairing some frames - and during this I was thinking about the postings here (post #42ff) in our forum.
With this in mind I wanted to store the already prepared frames in two frame-"towers" with one from midship fore and one midship aft, in order also to see the "nice fairing" for the clinker planking.
And I got a shock![]()
- it seemed that in direction aft the frames were all prepared wrong.
With these drawings (excerpts in the following) in mind, showing, that all floor timbers are into direction aft!
sideview and topview
View attachment 183933 View attachment 183934
and I got a 15 minutes "panic-attack"- I already wanted to write an e-mail to CAF asking for spare frames to make everything new....
How can this happen?
Why to me? Especially because at the same day I wrote such post like #42 !?!?
and I remembered also the last post by @Chello talking about the jig (#47) ..... best to check the frames inside the jig - a last prove before I write to Tom from CAF
So fast I removed the parts of the jig and stick some of the main parts dry together - putting the keel inside (it fitted well btw) and put all made frames on top of the keel inside the jig
AND:
Everything fine
all frames are in the correct direction (floor timbers in direction aft) and all frames faired until now also correct - PUH
I do not know, why I was thinking somehow completely in the wrong direction - black out
So here some photos of yesterday late evening (for info: jig only partly dry installed and no accurate arrangement of the frames - pure check situation)
Once more many thanks for all your kind words and likes ...... great and many thanks
based on the information given in the manual it is important. that the two other horizontal parts (No. 12 and 13-2) and are in the correct level. therefore there are two small cantilever at the jig.... (marked with red arrow)
therefor I put back the structure into the jig and assembled it there
afterwards once more outside
according the drawing the top beam (part No. 13-1) has a slightly different angle
For the installation of the vertical elements
I fixed the keel with the stern structure "frame" upside down with a Proxxon vice - here the finished result
and back into the jig - be careful, but it is working...... and fits very well
Finally, after some thinking, small changes, re-open and re-assembling I am very happy with the result.
I described my way how I did it, so I am very interested, if there are other ways possible, so maybe you can show your experiences here or in your building logs .....
Many Thanks for your interest ..... to be continued .....
...the slow you go, the far you can reach! Great progress, Uwe!AS mentioned already I am making very small steps with the planking of the second side
Maybe scotch tape - it's transparent. Looking great. I haven't seen hull so difficult to plank. You've done excellent job.Step by step ..... and soon it will be necessary to mark the locations of the nailing of the planks
So I tried fastly this way with a cardboard - I made ist fast, so not completely accurate, but it would work
I have to think further about alternatives ..... so if you have an idea, please do not hesitate
Dear UWEThese are the next information related to the jig given by the manual.
View attachment 185524 View attachment 185525
According Figure sketch No. 20 and 21 there are two options possible -
option 1 with closed side walls or option 2 with the open one´s with cut outs.
Due to the fact, that in my opinion it is very helpful to have a sideview possibility to check f.e. the connection between the individual frames with keel I decided to follow option 2
VERY IMPORTANT !!!
Take also a look in the manual No.2 inside the second box
View attachment 185526 View attachment 185527
View attachment 185528 View attachment 185529
And you realize, that for the future work you have to install "measuring sticks" through some holes in the side-walls which are defining the correct height of the internal structures......
You can see these prepared holes very good on this photo marked with the different arros (only a few are marked)
and you can easily see, that the holes are often located in the elements, which you remove for the before mentioned option 1 with open "windows".
Here one shown in closer view
So keep these parts and do not throw them away - You will need them later !!!!
Here you can see the topview with installed keel and the view through the window.
