LE COUREUR - french Lugger 1776 - POF kit from CAF in 1:48 by Uwe
I tried to make a "planking design" with the photo I posted some days ago.
Something like this I will prepare - this is the plan
Based on this idea I made also a copy of the drawing and marked the planks more in detail
Does something like this (see below) is also happening to you sometimes?
Yesterday evening I was working / fairing some frames - and during this I was thinking about the postings here (post #42ff) in our forum.
With this in mind I wanted to store the already prepared frames in two frame-"towers" with one from midship fore and one midship aft, in order also to see the "nice fairing" for the clinker planking.
And I got a shock :eek: Speechless :mad: - it seemed that in direction aft the frames were all prepared wrong.
With these drawings (excerpts in the following) in mind, showing, that all floor timbers are into direction aft!
sideview and topview
View attachment 183933 View attachment 183934
and I got a 15 minutes "panic-attack" Sick - I already wanted to write an e-mail to CAF asking for spare frames to make everything new....
How can this happen?
Why to me? Especially because at the same day I wrote such post like #42 !?!? :mad:
and I remembered also the last post by @Chello talking about the jig (#47) ..... best to check the frames inside the jig - a last prove before I write to Tom from CAF
So fast I removed the parts of the jig and stick some of the main parts dry together - putting the keel inside (it fitted well btw) and put all made frames on top of the keel inside the jig
AND:
Everything fine Exclamation-Mark
all frames are in the correct direction (floor timbers in direction aft) and all frames faired until now also correct - PUH
I do not know, why I was thinking somehow completely in the wrong direction - black out
So here some photos of yesterday late evening (for info: jig only partly dry installed and no accurate arrangement of the frames - pure check situation)
OMG
Once more many thanks for all your kind words and likes ...... great and many thanks
based on the information given in the manual it is important. that the two other horizontal parts (No. 12 and 13-2) and are in the correct level. therefore there are two small cantilever at the jig.... (marked with red arrow)
therefor I put back the structure into the jig and assembled it there
afterwards once more outside
according the drawing the top beam (part No. 13-1) has a slightly different angle
For the installation of the vertical elements
I fixed the keel with the stern structure "frame" upside down with a Proxxon vice - here the finished result
and back into the jig - be careful, but it is working...... and fits very well
Finally, after some thinking, small changes, re-open and re-assembling I am very happy with the result.
I described my way how I did it, so I am very interested, if there are other ways possible, so maybe you can show your experiences here or in your building logs .....
Many Thanks for your interest ..... to be continued .....
After just looking a a few pages of this amazing build log, I realize that “I don’t know nothing about model ship building”.
Somehow the planking work is getting more slow than before.....maybe I am a little bit bored,
but everything will end once.
I guess it will get newly interesting for me, when I reach the row of interrupted planking..... hope so
In the meantime I made a small test for the plank bolting. Somehow I would like to make the bolty like @Maarten is making on his amazing Alert,
But it looks like too much work for me
and
I am very happy and relaxed, because Jean Boudriot is not showing these bolts with washers etc. ;)
I tried to check this detail also with available photos in the web of scratch models of the Le Coureur or the Le Cerf to see how they made the clinker plank bolting, but I realized, that most or more or less all of them are not showing their clinker build hull in detail (or do not have the nailing or bolting shown) - seems, that this hull construction is not so easy and the results are maybe also not the best to show (but this is a pure guess by myself)
Here we can see brass bolts, a typical way french modelers are working
But
we have f.e. the very interesting building log of her Le Cerf scratch build made by Olha alias @shipphotographer.com with very good results
So I think, that I will do the bolting of the hull planking in the typical "french way", so I made a small test planking
On the left two rows only with pre drilled holes, in the center one row with brass nails diameter 0,7mm and on the right two rows with copper nails 0,6mm
For the photo I made the planks wet, to get an impression, how it will look like at the end after oiling the hull
I am expecting in the next days a delivery of copper nails with only diameter 0,5mm
I think it will be at the end the 0,5 or 0,6 copper nails
AS mentioned already I am making very small steps with the planking of the second side
Three or four more full rows of planking and I am able to start with the "window"
Here you see the actual status
Step by step ..... and soon it will be necessary to mark the locations of the nailing of the planks
So I tried fastly this way with a cardboard - I made ist fast, so not completely accurate, but it would work
I have to think further about alternatives ..... so if you have an idea, please do not hesitate
Maybe scotch tape - it's transparent. Looking great. I haven't seen hull so difficult to plank. You've done excellent job.
I don't know if is distortion of the picture but to me it looks like at least 1 maybe 2 lines for the middle futtock is slightly off:
Unfortunately I do not have any really good ideas for alternative ways. Maybe for midships frames you could use a wider or more solid strip of paper and also make it 4 mm wider along the middle futtock?
These are the next information related to the jig given by the manual.
View attachment 185524 View attachment 185525
According Figure sketch No. 20 and 21 there are two options possible -
option 1 with closed side walls or option 2 with the open one´s with cut outs.
Due to the fact, that in my opinion it is very helpful to have a sideview possibility to check f.e. the connection between the individual frames with keel I decided to follow option 2
VERY IMPORTANT !!!
Take also a look in the manual No.2 inside the second box
View attachment 185526 View attachment 185527
View attachment 185528 View attachment 185529
And you realize, that for the future work you have to install "measuring sticks" through some holes in the side-walls which are defining the correct height of the internal structures......
You can see these prepared holes very good on this photo marked with the different arros (only a few are marked)
and you can easily see, that the holes are often located in the elements, which you remove for the before mentioned option 1 with open "windows".
Here one shown in closer view
So keep these parts and do not throw them away - You will need them later !!!!
Here you can see the topview with installed keel and the view through the window.
Dear UWE
I'm building the Jig. Looks like your jig pictured above is just dry-fitted. I am not clear on one point: Did you glue the vertical parts A1-A7 to the slots in the B1-B2 base? I feel I need to either glue them to the base using a 90 degree metal square to insure they are perpendicular, or glue a square piece of wood 4-5mm/side to both sides of the the A to B joint. I suppose I could use short pieces of plastic 90 degree angle styrene. It seems to me that it would be ideal to be able to remove the A1-7 vertical pieces at a later phase in the build, using part of the jig to hold the keel in place.
