YUANQING BLUENOSE - Don Robinson
THANK YOU DON VERY MUCH ONE OTHER QUESTION, DO YOU FIND THE WELL BOND SETTING UP TO QUICKLY I HAVE HAD THIS PROLEM WITH WELL BOND ON THE FRAMES, THANKS. GOD BLESS STAY SAFE YOU AND YOURS DON
Hey all, I finally have an update to show. I did not bother to show all the frame installations as @Dean62 did a superb job of that, so if you haven't check out his log! Here I will show the stern and how it's made, it is a real test of your nerves and patience so here we go:
parts required for the stern, top left is 56 and then 57 beside it. The bevels have already been filed down on 56.
After lots of filing, sanding and dry fitting gluing started. Have a good look at these as it is the last time you will see them in this shape!!
some more added and the first two snapped off. These break off very easily and they broke more than once causing me to do the walk away several times. It was really pissing me off until I finally looked in the instruction book and seen that these will all be covered never to be seen again. Well out with the vodka and celebrating started, then another day off for healing. LOL So when this happens to you do not stress about it as it is not a big deal.
A quick overall look
Here is a picture of my crippled stern frames, like as said do not sweat it all of this mess will be hid.
Frames 58, the one on the right has the first bevel done
The second bevel completed
Third and forth bevels finished
Installed on to the stern, i am not sure what the little angle cut by the stern frame is for but it is on both pieces
Here I am about to start fairing frame 58 so I mark the frame it is attached to with pencil to help guide me. Gently using a sanding stick and resting it on the other frames to use as a guide I sand until the pencil lines are gone.
And here is what the end result looks like. You can see a few pencil lines remaining but those were gone when I sanded again with 120 grit
A final look to show the process, it is still not completely sanded but you get the idea. And you might notice another frame gone, this is the third time for that one so it is staying off until later when more support is added. Also notice the varying lengths of the frames this will also be left until later when the planking is added to try and trim these now is asking for a disaster and would be hard to do with any accuracy.
So enjoy this part, really TAKE YOUR TIME and have lots drinks on hand, you will need them! :p :)
Take Care, next up are the bow filler blocks.
Good Morning to all! First up is to Thank everyone for stopping in , giving likes and leaving comments. This makes me happy, in fact I'm so happy that if any of you are in the neighbourhood stop in and I'll pour the drinks. In Jimsky's case coffee and donuts!!!
A quick course in bow filler blocks:
So each block consists of twelve separate pieces, pair them up and glue together, do not clean off the hateful char just yet.
Follow this process until you have one piece of char left. LOL
It should look something like this when completed
When your finished sanding here is what you'll have.
Here it is installed
I'll be right back, grab another coffee!
Method two of filler block construction:
Now for those of you who tend to over sand, drop and break and generally screw things up here is how to fix things. Go through your scrap frame billets, I hope you saved them if not skip this process and go to liquor cabinet! Using table saw cut strips to width then to length and laminate together. Next is to cut the groove on the inside, this is done free hand so please no partying before attempting this!
Top line is showing the final size I want and the bottom line shows where the curve or taper is going to start
shaping has begun using belt sander
Final shaping done, new block on the left and the old on the right. Final sanding and shaping will be done inside.
I have pictures of final product installed on ship but I seem to have lost them. I'll go look for them and be back, good chance I left them by the vodka bottle. :p ROTF
Great job Don! Nice recovery on the scratch built side.
