Sounds like a forethinking preventative measure protecting what is now "hanging out there". RichThere are small gussets added in another step, you can add them now.
Well done. 123 blocks come in handy for all sorts of needs. RichBow blocking almost done, just a bit of fairing after the glue set well.
Pairs made up
Made a curve template to fair them in, but something was wrong. The template didn't fit the blocs.
Guess what, I missed parts #37. they were in a pair of clamps on the side of the bench, so on they go.
That's better. Faired them in to the template line and frame #1 curve, glued in place.
Just a bit of sanding when dry for a final fit.
Great job EJ!Bow blocking almost done, just a bit of fairing after the glue set well.
Pairs made up
Hi EJ,Thanks for all the compliments. I do struggle a bit now, as the eyes and hands aren't what they used to be. I do have a tough time applying 1/350 scale photo etch railings and stuff, but not bad for 79 years of age. I've got enough kits, probably 12 or so wood ships, 16 or so plastic ships, 6 or so and 4 aircraft (both wood and plastic) and amphibious vehicles to build. I'll never get them all done. Cripes, I'd have to live to 125 years old at the rate I build.![]()
The more that read about all of the breakage, the more content I am to continue with my larger 64 scale BN which at my pace could be many months until completion. RichI got the inner keel parts installed. Was a bit more fiddly than I thought it would be, but it's in there.
I'll now sand out the interior to fair things in a bit and true up some of the joints.
Next is the longitudinal beams, #135 and fitting the two parts B059 after that. Then Parts 136.
It seems that the upper deck beam supports, (102 and 103) are even with the lower end of the notch in the frames, (two levels).
But I'm confused as to where to position the parts 135 and 136. Is there a mark or something to go by?
I started putting in parts 24 thru 29, spacers? Someone called them waterways? I've gotten 4 of them in, but broke 3 of the 4. Are these used again somewhere else. If so, I'm screwed. Do I really need those things in there? I don't want to break any more of them if I'll need them somewhere else.
Also, is the inside of the blocking at the bow supposed to be faired in?
Hi EJ,I started putting in parts 24 thru 29, spacers? Someone called them waterways? I've gotten 4 of them in, but broke 3 of the 4. Are these used again somewhere else. If so, I'm screwed. Do I really need those things in there? I don't want to break any more of them if I'll need them somewhere else.
That’s what I wanted to write. Nice to see you find the solution to go one.The stepping-away moments are sometimes a crucial part of the build. You have found the solution and that is all that matters. Well done!
Interesting. I didn't check that.Those waterway boards are not very accurate. I measured differences of up to 1 mm between
notches, where they should be equal since the frames are all at the same spacing.
Didn't start my own build yet, only measured.
