Hello,
Kurt: thank for your encouraging words much appreciated –speaking of changing deck planks – well a few needed to be removed, but at a very convenient time – so far – and yes, not to your level of changes on your current build, but the Sergal needed to have a lot of changes from out of the box.
I did the same with my Corel Vasa – bashing the hell out of it……
Update -- Made the needed changes to the forecastle deck removing catheads holes just aft of mast. Added a cut for the lower halliard. Those catheads as I noted in an earlier post would have had no space to anchor to main deck given the inner two forward carriages.
Instead, decided upon halliard block; same as for main mast. And finished deck inner framing for grating and open area for stairs leading down.
Finished up installing and adding only partial carriage riggings as well, as well as deleting two carriages -- All of this work will mostly be totally hidden from view, but that’s ok. And the work is my no means accurate -a bit sloppy. Deck guns and carriages will be fully rigged and carriages properly detailed.
I used the white metal electroplated guns from the current kit, not from the vintage edition – did add recoil rings – arguably incorrect
Regards,
Corel Vasa - bashed
Hello, Here are some shots of my completed Corel Vasa. Please note that all ropes, blocks, deadeyes, and cannons are after-market. Much of the wood is also aftermarket supplied. For the rigging both standing and running used the Billings, Mantua, and the museum’s sheets along with photos of the...
					shipsofscale.com
Regards,
		 Rich
  Rich
