Oh...will not fit my Byrnes Saw.
But thank you!
12mm, 1/2 InWhat size do you need, I know how to search and will look for you.
Thank you for the research, Stephan. Yes Byrness using the American standard, but I can buy from Jim the upscale adapter to fit larger size arbor blades.@Jimsky the problem is that you use a Byrnes, that's American stuff. You need to shop in your stores for a replacement or change the arbor of your machine to 10 mm or 16 mm, that's what Ali express is selling. 12,7 mm or 1/2 inch is not available in our district. You also can contact Jim Byrnes for a solution. Maybe he's selling a replacement arbor in European measurements like 10 mm or 15/16 mm. maybe you can get a shim to fil up the gap in the arbor to a bigger bore. as I say 15 to 20 mm gives on Ali a lot of cheap saw blades
G'day Stefan, do you have a link to the buyer you got the saw blades from,Here it is almost Christmas every day
Today, very fast after ordering from the famous china online shop and very cheap Circle sawblades for my Proxxon FET. (around the 4 euro each)
4 differend saws and a little Japanese plane.
wood and metal (supposed to cut steel nails, I will not try, don't need it for that)
Plastic/wood and soft metals
Just wood
And this one is a wrong delivering should be a plastic cutter but send this thin blade, I opened a dispute and so I will get back the money. I will order the right on again.
View attachment 236635View attachment 236638View attachment 236639
The little japanese plane looks cute.
View attachment 236636View attachment 236637
Need to test is. The blade has some cover against rust that needs to take off. Then I will sharpen it to my wishes, wax the bottom and try it. Looks firm and strong hardwood. You need to hammer on the back by this type of plane to get the chisel out of the block. For that price I couldn't leave it in China(3,50)
best regards John,
Thank you Stefan,![]()
0.01US $ 99% OFF|Newone 10Mm Nitride Coating Hss Mini Cirkelzaagblad Hout/Metal Cutter 60T/80T Tct hout Slijpschijf Zaagblad|Accessoires voor elektrisch gereedschap| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comnl.aliexpress.com
It has a Chinese WEN tool look to it.....it'll work fine.receive this small, dremel-like today is not an original dremel or proxxon but will also do its job properly, I think?
greetings
willy
No Worries Allan I will hopefully be testing the saw today, I looked at the smaller saw but I think the blade is set, I could be wrong, and it was AUD 109, so for the extra 80 bucks I decided to go for the larger one,G'Day John, very interested to see how these new Ozito tools go.
I see Bunnings also have a smaller table saw but it it is only 800W as opposed to yours 2000W. The sander is very affordable I guess that 140W should suffice.
Any feed back on how they perform would be great.
Some more planks, these I cut today on my new saw, I was really pleased with the saw, it worked well, the fence was really tight and didn't move whilst cutting the planks and all the planks were uniform in thickness,G'Day John, very interested to see how these new Ozito tools go.
Thanks for that John they look pretty good seems the saw could be value for money.9
G'Day John, have you had a chance to give the sander a work out yet?9
G'day Allan, no not yet, maybe in the next few days,G'Day John, have you had a chance to give the sander a work out yet?
