I have absolutely no knowledge about it but when building a ship (or anything else) I think there are mainly 3 considerations to balance: the functional aspect, the aesthetic aspect and the economic aspect. Personally I cannot think of any technical or functional differences whether the nails are placed diagonally one way or the other. From an economic point of view I’m sure there is no difference . Hence I would put all weight on the aesthetical aspect and make the port side a mirror of the starboard side, exactly as you have done. That said, this reasoning raises immediately another question in my mind: Isn’t the same perspective just as valid for the deck planking? Shouldn’t the nailing in the port half of the deck be a mirror of the starboard side?I have one question and maybe somebody knows the answer, or have some opinion.I did not find any information in my complete library, so ......
Oriantation of the nails in the cravel planked area
In the meantime I was able to install the rail elements of one side and sanded them in the area of the gunports
Today I hope to finish also the other side .... to be continued
Many Thanks for your interest in my build
The floor, with the deck is a different case. If you do the symmetry as you wrote, then the bolts on the central board of the deck will match. Therefore, on the deck, the bolts go from side to side in sequence. I hope I explained it clearly. Uwe, sorry for the off top.That said, this reasoning raises immediately another question in my mind: Isn’t the same perspective just as valid for the deck planking? Shouldn’t the nailing in the port half of the deck be a mirror of the starboard side?
I understand your point but I'm still in doubt how it should be. In the mean time I tried to do some research. Unfortunately I did not find anything convincing in writing but I did find quite a lot of pictures (both models and full size ships) where starboard and port side of the deck was mirrored. A few examples.The floor, with the deck is a different case. If you do the symmetry as you wrote, then the bolts on the central board of the deck will match. Therefore, on the deck, the bolts go from side to side in sequence. I hope I explained it clearly. Uwe, sorry for the off top.
Real ship:
There are also contemporary models showing both ways of deck nailingI understand your point but I'm still in doubt how it should be. In the mean time I tried to do some research. Unfortunately I did not find anything convincing in writing but I did find quite a lot of pictures (both models and full size ships) where starboard and port side of the deck was mirrored. A few examples.
Model:
View attachment 249025Real ship:
But I also fould a lot of pictures were it was not made that way. Thus I'm still in doubt what way is most appropriate
The model in the model turned out very nice. It makes your mouth water to get the point yourself.The next part or small project in the project are the preparation of the two catheads at the bow
Here are as usual the sketches of the manual defining the elements necessary for the catheads
View attachment 249012 View attachment 249013
It is looking easy and the parts of the cathead in sheet 4D are looking very good -> so let us do it
But like mentioned before - it is a small project
On the left side you see the parts of one cathead partly still with the laser char. On the small wooden roller or wheels i left partly the char, so that they are a little bit darker than the beam by itself. So you have a little bit more contrast.
I decided to drill a hole through the complete beam with 0,5mm, so I can put the wheels on an brass axis, so that they are able to rotate
On the right the second cathead with temporary installed wheels
closer view on the beam
the wheels are rotating - I was thinking about sanding the wheels circumference concav, but they are really small and later on not really visible
Both beams are now prepared
comparing with Jean Boudriot drawings of the planset of the Le Coureur
Still some thing to do ......
wonderful work, well doneThe next part or small project in the project are the preparation of the two catheads at the bow
The fit between the parts and the body of the ship-deck, looks great and beautifulContinueing with post #893 and the work on the catheads
tem,porary installed, and the rail and arm not adjusted - in order to get a feeling and checking where and what has to be done
The vertical part at the rails is finished and fixed with "three bolts" and adjusted also with an eyelet
the three "bolts have to be added also at the nailing of the outside planking
also the second one
stepy by step I am coming closer to the end result
the top of the rails have to be also adjusted slightly, so that the cathead beam is laying on the rails - in order to fix it temporary I added an (later) unvisible nail
now tha cathead front and end has also the correct angle - vertical towards the sea-level
Now only the metal reinforcement band at the last end is missing The fit between the parts and the body of the ship-deck, looks great and beautiful
