Bluenose 1/72 POF [COMPLETED BUILD]
I modeled the lighthouse, I still have some windows to add, but this will give me dimensions to go by when I scratch build one.
I did a lot of research and found some dimensions... the base is 19 feet in diameter and it is 55 feet tall. About 5 stories high.
The most difficult part will be merging all of the angles, due to a octagon shape that tapers over the length up to the catwalk around the lantern house. And the corbels are in the corners, which should make for some interesting miter joints. ;)
At 1/72 scale, the same as the BN kit, it will be a little over 9" tall.
Thank you
Your CAD skills at 3-D modeling pay you large dividends beside your vocation. As to blocks . . . on my 64 scale BN I have limited myself to 3 mm on the low end but for a few associated with downhauls along the edges of some sails I may have used a few 2.5mm but the thread is very small as "threading the eye" becomes a challenge. Your lighthouse tower looks very promising. Rich
Thanks Rich. I have 4 and 4.5mm, singles and doubles, but might get some 3 and 3.5mm - just for kicks.
What a great idea Dean. 3D model a lighthouse and then scratch build it. I love it and may try it myself. I like your avatar, I have 12 different pictures and paintings of lighthouses in my office/drydock.
The precision of your bluenose is just a pleasure to look at and helps me to step up my game. Thanks for sharing.
Thank you Daniel.
There are some cardboard models available of lighthouses in 1/72 scale, that can be embellished into a very nice end result. But they are of light houses in Germany (which are very nice) and other countries, other than Canada.
So I decided if I added a lighthouse to the BN case as part of the display, it should be a lighthouse that would have been passed by the BN. Since there are no kits available of lighthouses in Novia Scotia, I decided to do some research. I found this one, the Louisbourg Lighthouse and read the history. It was rebuilt 3 times, the last time being in 1923. The BN was built in 1921, therefore I think it is safe to say the the BN most likely passed this very lighthouse many times in her fishing voyages! It is not the actual lighthouse in Lunenburg Novia Scotia, but that one was literally a house, and too big of a footprint to be placed in the case. So although this lighthouse was not in Lunenburg, it is still very feasible the BN would have sailed by it. And that’s good enough for me to use it. ;)
This will be about 3” at the base and over 9” in height at 1/72 scale.
So after doing research, I found enough dimensions to determine the scale for an elevation view I found. Then with a 3D model I can get dimensions for the pieces right off the model to scratch build. Seemed the easiest way, and I can see what I will get prior to cutting any pieces. ;)
Here is the some of the info I used…
Onto shroud lines…there will be no lighthouse until I finish the ship…lol :p
First I stain the deadeyes, I just use a toothpick inserted in one of the holes to hold them, then dip in the can of stain and wipe them off.
next… I put the shroud line around the mast and serve where it comes together. Then put my metal spacers in the lower deadeyes.
Next…I glue the shroud around the upper deadeye while it’s on the upper part of the spacer. Then I trim the excess rope to a predetermined length, so they are all the same. ;) Then I serve that with 3 small ropes.
Next…I paint the rope white to simulate the wrapping around the upper deadeyes and rope.
Next…time to remove my spacer and tension the shrouds with waxed rope. Then tie the lanyards hitches and glue before cutting off excess.
Next…the port pair of shroud lines will be added, then back to the starboard, etc. until I have 4 pairs finished. See you then! Happy modeling…
View attachment 254195View attachment 254196
It is clear that having the shrouds and deadeyes in place before the shear rod and rat lines certainly provides more access and working space for the deadeyes than if those are in place before the deadeyes. Good advance planning and execution for a very precise and visually pleasant presentation. Ric
