Yes, and very nicely set. I put in the photos in response to the question of gaff placement for other group members to consider. RIchThanks Rich…but my gaffs are raised!![]()
Thank you Eugene! I used the pearwood blocks from Dry Dock. The size is 5mm, anything smaller is too hard to get rope through!That is one sweet looking build.
If I may ask, did you use the kit blocks? If not, what size blocks did you use? I have some very nice pearwood ones from Drydock.
EJ
Thank youThank you Eugene! I used the pearwood blocks from Dry Dock. The size is 5mm, anything smaller is too hard to get rope through!![]()
Your CAD skills at 3-D modeling pay you large dividends beside your vocation. As to blocks . . . on my 64 scale BN I have limited myself to 3 mm on the low end but for a few associated with downhauls along the edges of some sails I may have used a few 2.5mm but the thread is very small as "threading the eye" becomes a challenge. Your lighthouse tower looks very promising. RichThank you
Thanks Rich. I have 4 and 4.5mm, singles and doubles, but might get some 3 and 3.5mm - just for kicks.Your CAD skills at 3-D modeling pay you large dividends beside your vocation. As to blocks . . . on my 64 scale BN I have limited myself to 3 mm on the low end but for a few associated with downhauls along the edges of some sails I may have used a few 2.5mm but the thread is very small as "threading the eye" becomes a challenge. Your lighthouse tower looks very promising. Rich
You will need a couple of triples too!Thanks Rich. I have 4 and 4.5mm, singles and doubles, but might get some 3 and 3.5mm - just for kicks.
I thought that the smaller sizes were more in the 64 scale of my BN but from the sail/rigging plan sheet I did upsize some of the smallest to 3 mm. RichYou will need a couple of triples too!![]()
Thank you!Great work on the 3D modeling of that lighthouse Dean!
Thank you Daniel.What a great idea Dean. 3D model a lighthouse and then scratch build it. I love it and may try it myself. I like your avatar, I have 12 different pictures and paintings of lighthouses in my office/drydock.
The precision of your bluenose is just a pleasure to look at and helps me to step up my game. Thanks for sharing.
It is clear that having the shrouds and deadeyes in place before the shear rod and rat lines certainly provides more access and working space for the deadeyes than if those are in place before the deadeyes. Good advance planning and execution for a very precise and visually pleasant presentation. RicOnto shroud lines…there will be no lighthouse until I finish the ship…lol
First I stain the deadeyes, I just use a toothpick inserted in one of the holes to hold them, then dip in the can of stain and wipe them off.
next… I put the shroud line around the mast and serve where it comes together. Then put my metal spacers in the lower deadeyes.
Next…I glue the shroud around the upper deadeye while it’s on the upper part of the spacer. Then I trim the excess rope to a predetermined length, so they are all the same.Then I serve that with 3 small ropes.
Next…I paint the rope white to simulate the wrapping around the upper deadeyes and rope.
Next…time to remove my spacer and tension the shrouds with waxed rope. Then tie the lanyards hitches and glue before cutting off excess.
View attachment 254195View attachment 254196
Next…the port pair of shroud lines will be added, then back to the starboard, etc. until I have 4 pairs finished. See you then! Happy modeling…
