Warning: Before any more shrouds, anchor the bottom ends of those chainplates to the hull. After tensioning and finishing a few more of the shrouds and deadeye lashings, the tension will be great enough to break the channel right off the hull! Then you'll have a small mess on your hands trying to get it back on the hull in the correct position. The tension force of each shroud is supported by the chainplate anchored to the hull. There should be no vertical force applied to the channel (chainwale). Before lashing the deadeyes, each chainplate must be firmly nailed to the hull below the channel, with the nail positions on a wale, if there is one. Rattlesnake does not have wales, but the it does have a hull strake that transitions from the lower hull, which is thicker, to the upper hull, which is thinner and lighter in order to save weight.
