The pillars are in place
testing the correct height (and alignment) with the horizontal rail
some small adjustments were necessary in order to get a smooth alignment
But be aware: Before you fix the rail, please drill the small holes for the oars - the basis for the oars are exactly in the same fall line and under the rails. If the rail is fixed you can not drill any more
I made also the other one and fixed the height and drilled all holes
just for fun the "oars" on some locations midship
top view with all drilled holes for the oars and prepared pillars for the rail
