A fantastic development, looks very, very good. Also wish a nice weekend.
Many Thanks for your comment - high appreciatedThis really good work, Uwe. You are setting an excellent example to the rest of the Group builders with your efforts. Maybe you can ask Tom for a replacement left window frame on the stern?
Ja - and I want to state, that with this extreme good basis of a well designed and high quality material in the kit you can make a really good model.Einfach nur toll.
drydockmodelsandparts.com
Hello Uwe, you can really be more than satisfied, looks flawless.Going further with the hinges of the rudder.
To imitate the bolts with which the wooden part of the rudder were fixed to the hinges I drilled some 0,5mm holes into the brass hinges with 1,2mm width
and insterted once more the fine "tiny nails" from @Dry-Dock Models & Parts
These nail heads are fitting well and looking like the bolt heads.....
View attachment 253626![]()
Tiny nails ( brass)
The brass nails has a flat end not spiky ,also the shape of the head is round and flat Diameter 0.3 mm ,Head 0.5mm, lenght 4mm Diameter 0.5mm , Head 0.7mm , lenght 4mm Diameter 0.6 mm , Head 1mm , lenght 6mmdrydockmodelsandparts.com
overlength removed and ready for blackening
but before once more a dry fit on the rudder - also compared with the drawing of Jean Boudriot´s Le Coureur
But now they can be blackened
and here the rudder in place - approximately at this place it will be installed (the end of the rudder has to be slightly higher than the bottom of the keel)
It is looking nice - I am happy with the result
(a little bit higher than shown here)
Many Thanks for your interest - next post will show the second parts of the rudder-hinches
Hallo Alexander,Very good job, Uwe.
The rudder looks very authentic.
Are the stern decorations ready or do you plan to paint or gilden them?
Grüße, Alexander
