LE COUREUR - french Lugger 1776 - POF kit from CAF in 1:48 by Uwe
The pillars are in place
testing the correct height (and alignment) with the horizontal rail
some small adjustments were necessary in order to get a smooth alignment
But be aware: Before you fix the rail, please drill the small holes for the oars - the basis for the oars are exactly in the same fall line and under the rails. If the rail is fixed you can not drill any more
I made also the other one and fixed the height and drilled all holes
just for fun the "oars" on some locations midship
top view with all drilled holes for the oars and prepared pillars for the rail
Nice work. Those oars will definitely help pull along as you progress. :-) Rich (PT-2)
Nice work. Those oars will definitely help pull along as you progress. :) Rich (PT-2)
The finalization of the oars with correct shaping is coming soon - so we can also "sail" during calm times
BTW: If there is no wind and a vessel was pulled by oars - is it still "sailing"? Question about the correct term .......
Finalizing the rails, which were started in yesterdays post.... some final cleaning of surplus glue and a final sanding with fine grid is still necessary, but is fitting very well
still you can see some sawing dust - so you can see, that these photos were done during the work
looking along the rail
especially this area need some finetuning before I will oil the timber
That railing with the tight fore curves and transom gentle rounding is a very good execution! It looks like one piece. Well done! Rich (PT-2)
My friends - many Thanks
BTW: Adi - nice new photo (Avatar) :cool:
One small work was done with installation of a single sheave block the bow necessary for the later rigging of the bowsprit.
Remember, that the bowsprit was not permanent fixed, but could be partly pulled backwards
The axis is fixed in the keel, so the wheel can be turned, the visible end of the brass will be also blackened later on
Great work Uwek, she is beautiful!
Great work Uwek, she is beautiful!zI
Wonderful workmanship Uwe.:)
Under way without sails or wind and only being propelled by oars is at least "headway" unless the heading currents are actually pushing backwards in her actual track. Together hearties, heave with a will!!! Rich (PT-2)
Many Thanks for the comments and all the likes received
I order to know and prepare everything what is necessary for the deck I decided to make the oars. In the kit are 8 oars included and laser cut prepared
Here for fun are four "raw" oars shown at their location at the oar crotches
This is what the manual is telling us - unfortunately now oars are shown in the drawings
Boudriot is writing in his monograph:
the oars are 35 feet in length and operated by four men. There are 9 crotches on each side, but the vessel cannot be fitted with all oars out at the same time due to lack of crewmembers
and he is also writing
The oars are stored either on the deck against the ship´s boat or alongside the hull in iron crotches fitted towards the stern.....
Reading this I decided to check the possible installation as soon as possible.....
BTW: I do not know any scratch Le Coureur showing the oars, so all or better most modelers avoided the problem of storage
So, sanding is a must and the main work on the oars of the Le Coureur - here you see on top a sanded one and at the bottom a raw version (unsanded)
both are laying on a Boudriot drawing (showing the oars and all the mast and yards)
Here most of the sanding (I made it by hand) is done
CAF is proposing at the end as a handle knob a piece of 2mm wooden rod, but I rememberd some spare parts from an old Mantua kit, which could be adjusted to fit the needs
Here the Proxxon was helping very much
OK - still not so slim like Boudriot was asking but better
8 handles are prepared
The top one was a first trial, which was later removed and also downsized in the diameter
better and final solution - there are only 6 more to make - Here I am very happy, that in the kit are "only" 8 oars included - Puh
Hope to show tomorrow the final oars
Your work on the oars and handles looks very well done. I like the reshaping of the belaying pin shaped handle for a more realistic grasping profile. Rich (PT-2)
Finalizing the oars
Comparing with the Boudriot drawing of the Le Coureur
- after some time of carefully sanding I finished all eight oars
I have to state, that CAF prepared for the kit really very good timber - for parts like these oars you finaly realize how important is a good timber you are working.
The oars are flexible and you can bend them without braking or cracking, the grain is running exactly along the length of the oars, so no problems at all during sanding and preparation - Bravo @CAFmodel for such a kit
At the end of this post -> PULL - PULL - PULL
Finalizing the oars
Beautifully executed build, highly impressed.
Johan
Many Thanks my friends for your kind words !!!
Were the oars used for navigation (in combat) or also for locomotion over longer distances?
Hallo Thomas,
sometimes the oars were used during really calm wind, to "sail" but I guess not really during combat - the seamen were necessary at the guns.....
But usually they were necessary near the coasts - Especially this type of ships were used near the coasts (with all problems of the tide in the northsea)
Also important to know: sometimes the french harbors and / or shipyards like f.e. Rochefort are located at rivers, 5 or 10 km landwards from the coast. Bigger ships were pulled by their own boats or also sometimes by horses walking at the bank of the river. Smaller ships like Le Coureur used at this time their own oars assisted by the boat
Here you can see the actual Hermione pulled by a motorboat on the river Charente near her homeport Rochefort
Sorry, Mon Ami, unless the tug boat is attached from the port-side (no visible), I don't see how this small motorboat can pull Hermione. If you look closely, you will not see any tow-cables attached. Also, given that she has some sails 'ON', she might sail on her own, IMHO. ;) But...I could be wrong...
