Heinrich, I think MR. Murphy has been lurking in basement for a number of years. Every time I've had a group over for a RR running session, he seems to be the first in the door.Mr Murphy is never one to be underestimated
Jan
**VIEW THREAD HERE** |
Naw, I just bumble along. I'm in no particular hurry, just having a good time learning as I go.Wow! Moving along quickly!
It’s great to see your work. Murphy is truly everywhere and he comes at the worst times.Many thanks to all of you who stop by and check out what I'm up to. Always feel free to chime in at any time.
Jan
Hi Peter,Hi Jan,
I'm beginning to believe that Mr. Murphy has something to do with paddle steamers. He has also visited me a few times.
But it's nice to see that you were able to rebuild it. And scratching with your own material is very satisfying.
Hopefully your basement will soon have a good climate for the trains and the Chaperon.
This is a beautiful picture of your progress Jan! The boiler is an impressive structure - I cant wait to see what details you will add.Todays effort:
The rear structure pieces both Port and Starboard are set and glued in position. I've not "squared" the front part by the boiler or added the staircase. I want to work on the boiler and then add some bracing or beams to help support the boiler deck floor.
Jan
With a ship with such long lines, you can quickly see a deviation. The photo shows the beautiful flowing lines of the hull. And the structure fits nicely on the MainDeck. Good that you are thinking about extra support for the boiler deck.Todays effort:
Jan
Looking good. I noticed that it looks like you had added the roof support runs that the boiler area stationeries attach to. These runs can’t attach to the front entry structure as they will interfere with the smoke stacks. The need to be trimmed to stop at the final stationary. You may already know this but just wanted to alert you. The plans show this incorrectly but the instructions do highlight this issue.Part of the custom detail mix:
My inspiration and a detail borrowed from the well documented SOS "Robt. E. Lee". The waterline. Since my hands aren't all that steady and my eyesight is "iffy" for close work, I resorted to 1/16 inch red "MATTE" graphic tape for this little project. A coat of "True North Gloss Coat" holds it in place.
Jan
@Barry1,Looking good. I noticed that it looks like you had added the roof support runs that the boiler area stationeries attach to. These runs can’t attach to the front entry structure as they will interfere with the smoke stacks. The need to be trimmed to stop at the final stationary. You may already know this but just wanted to alert you. The plans show this incorrectly but the instructions do highlight this issue.
Hi Heinrich. I'm learning, slowly but surely I'm learning .Hi Jan. It is good to see that you have read ahead and made the necessary contingency plans. To be forewarned is always a good thing!
Indeed it does!!Pictures to go with Post #194.
The area of concern mentioned by Barry1. Before the Boiler deck is added this part of the support brace has to be removed so the short pieces for the Boiler smoke stacks will fit after the Boiler deck is added.
The arrows point to the Boiler deck support piece that needs to be removed.
This view shows how the Boiler deck will fit. The arrows point to the pieces of the support structure that need to be removed.
I hope this shows what Barry1 pointed out.
Jan
